Hello all! I have a 2006 ST1300 that needs a brake pedal switch. Anyone done one of these? I want to attempt to replace it myself but don't really know how. Thanks in advance!
How would go about adjusting it? I think you can see it through this little rubber covered window above the brake pedal.You sure it doesn't just need an adjustment or loose connection fixed?
An addendum to my earlier post. That quote I gave you was to test the switch. To adjust it, the manual simply says to hold the switch body and turn the adjuster. Yes, sometimes the manual is as clear as mud. I'd pull the black textured lower cowl and see what kind of acces this gives you. Maybe someone else who has done this will chime in. I suspect you will have to remove the middle cowl to get to the top to disconnect it from the wiring harness.Hello all! I have a 2006 ST1300 that needs a brake pedal switch. Anyone done one of these? I want to attempt to replace it myself but don't really know how. Thanks in advance!
Hold the switch body (in the middle of your little window) as you rotate the knurled nut (at the bottom of your little window).How would go about adjusting it? I think you can see it through this little rubber covered window above the brake pedal.
