Where would I find the Info/Directions for the 40-Amp Upgrade ??
Thanks to all...
Wayne Cornell
Thanks to all...
Wayne Cornell
My opinion is that over time there could well be demand for 10 of the aluminum plates. However, I suspect that the other unique part necessary for the upgrade, the hardened steel splined shaft, will also soon (if not already be) no longer be available NOS; a far more expensive part to custom manufacture. Something to consider...
Larry, it might be worth reaching out to this geezer who seems to be all things for ST alternators.I have gotten a price estimate for adapter plate duplication: $450 for one or $350 each for ten.
Is that reasonable? Would there be a demand?
Yes, that is the part: 13411-MAJ-G20John, is this the shaft[?]
Hardly...Is the 28 amp alternator not rebuildable?
Well, the next step is to take it to a shop and find the closest match to the configuration, then machine an adaptor, or case, or shaft to make it work. Granted, my view is a bit jaded as I have a machine shop, and machinist at my disposal, but this really isn't rocket science and would be hard pressed to sell a bike for this reason.Hardly...
- stator freeze shrunk into casing
- everything sealed with Resin...
Would you be interested in pricing duplication? I can gather some pics, and send you a plate if necessary.Granted, my view is a bit jaded as I have a machine shop, and machinist at my disposal, but this really isn't rocket science and would be hard pressed to sell a bike for this reason.
Larry's machinist's pricing is not realistic. $300 for that part, in a bulk order?
Yes, I have looked at the posts. Repairing the 28amp appears possible if tedious. What I'd like to see is the mounting side of the 28amp compared to the 40amp adaptor plate and shaft. Could the 28amp unit be modified into an adaptor plate and shaft for the 40amp unit? There has to be commonality, they bolt into the same place on the engine. Or could the 28amp unit be modified into an adaptor plate to allow the installation of another type (non-Honda) alternator? Trying to think outside the box.
‘The stator is the part that fails, it‘s on the far right in my photo. Plenty of images of it in the links I provided above.
