OK, here is my idea: Cut down 28amp alternator shaft, cut down engine side of 28amp case. Unable to tell if there is an intermediate bearing at the front of the 28amp unit. A bearing will be needed to be added here if not. As I understand it, the 28amp case is open to the crankcase for cooling purposes? If so, a sealed bearing will close this off. Install a Lovejoy type coupling on the cut down shaft. Find suitable small alternator, there are many 30-40amo units that may work. Lovejoy coupling to the small alternator shaft. Then standoffs, legs, machined mount to support alternator to back side of cut down 28amp case. No idea if this would fit in the space, but it's certain doable. I've seen lots of industrial stuff driven in this manner. RT
