Well I have started it the last two mornings about 50 degree here. Both time I cranked it no choke it wanted to start but it did not. Continue cranking and pull the choke on. Take the choke off and crack the throttle and it fired up. Today was bad. Hard to start and when it did start was running on one cylinder. Even revved up you could here another cylinder fire now and then. Took my infrared thermometer and the left side was not firing. Shut it down and saw some fuel drips under the motor. So the carbs will have to come off and check the needle and seats.To me, the big key on the fuel pressure is whether or not you need to 'choke' it when the engine is cold.
If you don't there's too much pressure IMHO.
Glad it's working for you now!
Ron, Thanks for telling me the name for the FWD pegs. STeed STicks.. I get it!! I did search on this forum and there was an article in 2009 about some one bought a set $250. and the weld was cracking. When he got into it and saw it was a bad weld. The maker did not warranty it. I look a little at them today there is no weld on mine. Just pressed 1/4 steel. I see your point of reversing the mounting to use the "wing" covers. When I put them on I will try mounting them the other way. I would still like a picture of how they should look. Most of my hardware was missing and one wing cover is missing and the other busted up. Not going to worry about that till I get it running well first. I repaired the Headlight Garnish the other day. Mounting tab was broke off. I have the right side mirror glass and cover to repair also. I now need to pull the carbs off again and see what is going on with them..I believe those forward pegs are Steed Sticks from quite a while back. No longer available. I also think they are mounted upside down and on the wrong side. If you swap sides and mount them on top of the black wing brackets, you can carefully calculate where to drill the hole in the plastic "wing" covers. The screws have to be flush with top of the black angle iron piece for the wings to fit. I'll see if I can get a picture of mine tomorrow.
