During the Covid lockdown, I thought I would overhaul my braking system (other than the SMC) and my question relates to accessing the Rear Brake Master Cylinder, which I need to remove.
The Service Manual(SM) says the Step Holder (i.e. footrest bracket) has to be removed. This bracket is held in place with 4 bolts and links 2 parts of the sub-frame.
Now a number of members and the suppliers of the aftermarket rear crash bars, have warned about NOT removing both of the 2 rear bolts simultaneously. However, I cannot see how the bracket can be removed without removing all 4 bracket bolts, without making a metal bar linking both parts of the sub-frame in order to provide the same support.
It should be noted that the SM gives no warning of possible sagging nor that special action needs to be taken.
So I have 2 questions:-
1. How serious is the risk of the sub-frame sagging slightly and
2. if the risk is serious, what can be done to remove it?
I am sure there must be many members out there who have refurbished their rear brake master cylinder, and so are able to comment on their experiences.
Thanks
Paul
Thanks
Paul
