adding an additional brake light to the bike
Wasaga Beach, Ont. Canada
'04 ST1300 Blue STar
My 10" Admore smoked rear light bar continues to work well on Blue STar, after being transferred from my CB1000c. So a total of 4 years service on it now. Mounted just under the Givi plate, it is well positioned to be in the view of overtaking motorists. The new model, with the accelerometer is the way to go now. Well worth the few extra $$,,, Cat'
I went with the Admore strips, later added a LED strip above the license plate and then saw a Knight Riderz light on a Yammy in the Adirondacks in NY. Could not take my eyes off that moving light. Check out customdynamics.com for these lights - they draw your attention. Yup, I added one of these below my license plate. No stops by the gendarmes yet.
West Michigan
'98 ST1100
8470
Being retired and on a fixed income ( and being the cheap ba**ard that I am ), I mounted a fairly bright red LED aux light to my rear fender under my license plate energized with a solid state flasher. Total cost was about $14.
Dan T
CT
2002 ST1100
I received my Whelen Lin3
and a set of yellow X-ARC signal lights which I'll locate near the saddle bags. I have a couple of weeks before I can install them put once I do, I post some pic's.
Martha Lake
F900 XR
000800
I've used the Knight Riderz LED Light Bar on three bikes now. Cost is $29.95. It's simple to set up and works well. I try to set it up as high as possible and away from the rear brake light. The idea being to have a second light come on when the brakes are applied and be more attention getting.
The "Knight Riderz" is a reference to the lights on the Knight Rider car from the TV show. The used to have this cool look of going back and forth. You can do that with these too. I chose to have them off till the brake light comes on. Then it flashes rapidly, slows down, and then goes on solid.
+1 A very sound and popular idea.
GadgetGuy1230 said:
Added the Whelen Lin3, replacing the reflector on the rear fender.
Another popular farkle. I moved my reflector down to the bottom hole in the fender that's possibly meant to mount the large license plates used in European countries.
GadgetGuy1230 said:
Just put on a programmable brake light flasher (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1).
What light is this connected to? The LIN3 is also programmable yeah?
GadgetGuy1230 said:
My riding buddy says it's a good attention getter.
Oh yeah! When you come to a stop in traffic check your mirror. You may see your new brakelight reflected off of the car behind you. Sometimes cars will stop over a car length short of you. Sometimes they creep up so that the strobe doesn't flash in their face. It is bright. :cool:
Martha Lake
F900 XR
000800
On the each bike, I've made a plastic "bracket" from a black bottle of moss killer. (We use a lot of moss killer in Seattle.) I cut out about a 6 inch length from the side of the bottle where there was a bend and cut it down to size to match the Knight Riderz bar with room enough for two screws to mount it to the underside of the rear top case carrier. And yes, to fasten it to the plastic "bracket", I just used the 3M tape they provide. It worked great.
Dublin, Ohio
2007 ST1300 ABS
Good idea, I may put that back on or add some reflective stickers on the back of the bags
Flasher/Modulator is on the LIN3
LIN3 is programmable, 27 patterns, however no patterns flash then stay on. I set the LIN3 to just ON and let the modulator flash about 6 times in a second then stay on.
Oh yeah! When you come to a stop in traffic check your mirror. You may see your new brake light reflected off of the car behind you. Sometimes cars will stop over a car length short of you. Sometimes they creep up so that the strobe doesn't flash in their face. It is bright. :cool:
Still got tailgated 3 times on a 180 mile ride the other day, flashy brake light had no affect on one of them (had to pull off and let them pass). Yes sir, it is bright, I like it.
Got it.
There are always exceptions. Certainly nobody wants to be tailgated but at least these guys were probably very aware of you. Much worse is a driver who rolls up on you somehow unaware of the space and time you're occupying.
We know that almost nothing works 100% in all scenarios but the LIN or equivalent is a welcome addition.
st11ray
charlotte, nc
'06 ST1300
7189
I have hyperlites on the reflector brackets and a Whelen stop, tail, and turn signal light bar mounted to the bottom of my Givi rack. The Whelen flashes and goes solid like the hyperlites. It also has running lights and turn signals. I tried to get mine as high up on the bike as possible to get the light "in their face".
Dan T
CT
2002 ST1100
You guys that added these lights as brake lights had to power the light from the OEM brake light wire right. I don't see any other way of doing it but I had to ask. I'm reading the direction and it says to power the light from the battery using a fuse. This can't be done if it is supplementing the brake light. Am I off track on this? LOL
Yep that's what I did. The lights are all LED so the current draw is very little. The brake light wiring doesn't even realize there's an added load.
No you're not. That instruction might make sense if there were three wires and some kind of switching device built into the light assembly— fused positive lead to battery and negative lead to battery with a trigger wire going to the brake light switch or brake light wire. Do you have a link to your light in case there's something we (or me) are missing?
Like I said all my 'hot' leads go to the hot brake light wire and the negative leads go to a nearby ground.
Grand Junction, Colo.
92 ST1100
Close..lol. You can just tie it in with the existing brake lite wire AND ground wire. Did same on mine when I added the optional brake lite(4 LED light) in the recess of my GIVI tail- trunk. Myself, just removed seat to get at wires in the location where the factory tool kit is located.
North Plainfield, NJ
'06 ST1300A
Don't forget, the OEM brake lamp circuit is already a "from the battery using a fuse" circuit.
Are you aware of this thread addressing the same topic running concurrently to your thread? You may find some useful information there, as well as a schematic indicating one methodology of wiring an additional brake lamp.
Ron
Orlando
ST1100s
2432
The Whelen TIR3 (Uncle Phil's recommendation) is visible a mile away in broad daylight. It will hurt your eyes at 10 feet.
