This is exactly how I do it. But it takes a bit more strength than I can easily muster. A few months in the gym just for drill would benefit me in a number of ways.I think of it as using my body strength to separate the lift handle from the stand pedal. The bike just goes along for the ride.
That would be the informative bit. Because without any lifting I'd think you could center stand the bike with no hands. Well maybe a finger or two to keep it vertical until both centers stand feet touch ground before putting it on the stand.And yet somehow...
There are variables as mentioned. Anything that reduces the height from the center stand pivot(s) to the ground adds resistance to getting the bike on it. Tire pressure tire diameter (as in smaller that factory tires) possibly preload adjustment modification to the front and rear suspension are all things that alone or in concert would affect standing the bike to different degrees depending on the individual owner. A good tailwind might impeded my ability.I don't know why there would be a difference.
Now that's what I'm talkin' bout.I put this under the rear tire,and the bike went up with me just standing with my weight on the center stand. Easy. 1/2" made all the difference. No lifting. Thanks!
This would seem to work in conjuction with Larry Fine's method.You use the strength of your leg, not the deadweight of 200+ pounds.
I've seen the video of a 12yro girl lifting up a 'Wing. I haven't seen her lift an ST1300 and fully doubt she could do it. You're talking apples and oranges.There are videos on YouTube.
Glad you got it sorted! Amazing how small things can make a huge difference.Update 3-8-20. Removing, emptying/cleaning, and refilling the dampening unit and shock line with oil, I was able to set the preload correctly (thanks Igofar) , set the rear tire pressure to 42#, and I can now put the bike on the center stand by stepping down on the tang and using the spring loaded lever to steady and leverage
as I lean toward the rear of the bike ,without any problem. I believe that low tire pressure and the absence of oil in the damper had alot to do with the problem I was having. I also am sharing a pic of a fastener I found to work well with the front faring windshield area. Many thanks to all members.
Remove and refill the preload adjuster. It can be done in 30 minutes if you don't dally. Dduelin gave you a few good links above.I assume insufficient rear preload can cause the bike to squat in corners too. I seem to touch the side of my boot all too often.
I checked my ST's preload this morning, which I had set at 7 clicks ages ago (I am a solo rider). I found I could roll on a further 7 clicks before meeting any resistance at all, and I stopped at 14.
Any ideas on what I can do now would be appreciated.
Thanks D
THANK YOU!the preload does not make the suspension stiffer. The preload just lifts the back end so that when rider, pillion and luggage are added, the ride height is correct.
Shawn, I’m one of those people not too familiar with suspension. I was under the impression that adjusting the preload higher, would in fact make the rear end respond “stiffer”. Is that not the case? (Or does it simply and only raise the rear, so if I have a load on the rear, it doesn’t bottom out when hitting a bump?)THANK YOU!
I used to be a part of another bike forum where people were ALWAYS mistaking increased preload for "stiffer". I got tired of trying to explain that once you're compressing the spring, all that additional preload does is raise the ride height.
There's an awful lot of people who fundamentally misunderstand how suspension works.
That is correct. It doesn't make the spring stiffer. The only way you can make the spring stiffer, is to put a stiffer spring in ! In fact, raising the rear is a side effect. The piston inside the damper needs to be roughly in the middle when you are sitting on the bike (with load). That gives it the full range of travel up and down to cope with bumps. If you are going to put more load on the bike, then you need to wind that piston up a bit so that it is in the middle when you get on the bike. The effect of that, is that it lifts the tail.Or does it simply and only raise the rear, so if I have a load on the rear, it doesn’t bottom out when hitting a bump?
In regards to setting preload know that the 900# spring on the stock ST1300 shock is optimized for a solo rider of 180 lbs or less. The spring cannot be adequately preloaded for significantly heavier riders and probably all two-up couples. We know this from static and rider sag measurements.Shawn, I’m one of those people not too familiar with suspension. I was under the impression that adjusting the preload higher, would in fact make the rear end respond “stiffer”. Is that not the case? (Or does it simply and only raise the rear, so if I have a load on the rear, it doesn’t bottom out when hitting a bump?)
Also, on the right/starboard side of the bike is a H/S screw adjuster. Does that do anything to suspension? (Am assuming that one Hardens or Softens it.)
As jfheath and dduelin pointed out, spring rate is fixed. It's measured in lb./in. (the number of pounds of weight it takes to compress the spring one inch). In Metric countries it's kg/mm, but the same principle applies - weight vs. amount of spring compression.Shawn, I’m one of those people not too familiar with suspension. I was under the impression that adjusting the preload higher, would in fact make the rear end respond “stiffer”. Is that not the case? (Or does it simply and only raise the rear, so if I have a load on the rear, it doesn’t bottom out when hitting a bump?)
A stock ST1300 shock's rebound adjustment is a screw with approximate 3 turns from full soft to full hard. It doesn't have numbers or notches. Do you have an aftermarket shock with a different method of adjusting rebound compression?As jfheath and dduelin pointed out, spring rate is fixed. It's measured in lb./in. (the number of pounds of weight it takes to compress the spring one inch). In Metric countries it's kg/mm, but the same principle applies - weight vs. amount of spring compression.
The only way to increase "stiffness" (resistance to compression) is to replace the spring with one that's stiffer (i.e. higher lb./in. rate). That's the whole basis of the aftermarket suspension industry.
Assuming that you're using a stock rear shock and that you're not going to go through the process of replacing the spring, then you need to make sure that your preload / ride height is set correctly. To do this, you need to start by making sure that your preload adjuster is emptied and completely refilled with fresh oil (there are threads on the forum about this). Turn the adjuster knob fully counter-clockwise (zero preload), then put on all of your riding gear and sit on the bike. Have someone take a tape measure and measure from the ground to the bottom of the rear fender. The measurement you're looking for is 12.25 inches - if it's less than that, then start turning the preload adjuster clockwise until you reach that 12.25" measurement at the fender.
(NOTE: The fender measurement I gave you is a poor-man's shortcut. I'm not complicating things by explaining the proper method of measuring suspension sag. Long story short, you should have about 30% sag with a rider in full gear sitting on the bike, which on an ST1300 is 1.5 inches of sag, which correlates to 12.25" from the fender to the ground, assuming that you have a stock, unmodified fender.)
After that, turn your attention to the rebound damping adjuster (the screw adjustment at the base of the shock, on the right side of the bike). The rebound damping adjustment controls the speed at which the spring extends to it's normal length after being compressed. The higher the number, the more slowly the spring extends after being compressed. Since you're coming into this topic fresh, my recommendation is that you place the adjuster at the #2 setting (or the second notch from fully counter-clockwise). In all honesty, that'll probably be just fine for most riding, and will keep you from getting bogged down with excessive tinkering.
