So I need so advice on what could be the issue.
I recently rebuilt my SMC and bled the brakes in sequence and tilting the front left caliper.
Now the front brake works perfectly and the rear works perfectly however it I apply both and then release the front brake such as coming to a stop and keeping the rear down I lose all pressure and have to pump the rear brake once and then it's perfect again, no biding.
Now on centre stand I applied both brakes wheels stop I push on the smc the rear stops and then free wheels once smc is released but I can't seem to figure out why when I'm riding the rear loses pressure.
I have zero brake binding and all works as should.
I also have a clunk sound coming from the smc at slow speed but dose disappear if I apply front brake. Might clunk at higher speeds but I can't hear it.
My thinking is the smc bore has ovalled and changing the seals wasn't the issue and the piston is still sticking. My other thought is air in the system still but I just haven't got it out after 3 bleeds.
Any advice would be appreciated.
Cheers jono
Cheers jono
