Slydynbye
Will ride for Pie
Why confuse the issue? If you do it properly there are less doubts, it's only a couple ounces of brake fluid.
This looks like a good opportunity for someone to find and post the braking system animation.
Is this it?
Simply put, the front brake lever activates BOTH front and rear calipers, as does the rear brake pedal. It's a linked system so bleeding the entire system every time, is necessary.
You may want to re-think your thoughts on being able to bleed the rear system, and limp back on the front system.
It does not quite work like that
Is that like having a front flat tire and just wheelieing the bike all the way home?Instead of just bleeding the SMC loop, let's say I remove the SMC, I remove the rear MC, I remove the rear caliper.
Then the front lever will still activate the 4 front outers whenever I pull it, just as it does now when I sit on the bike, no difference moving or not. Enough to limp for a while, no?
I’m gonna have to go with No, and let somebody else try and explain it to you as I’m in the middle of a job right now.
Let's hope to hear from Langley863 that his pedal drop is gone as well!...... After that bleed the pedal drop was completely gone and never returned. ......
Was unable to get out and bleed it today bit did yesterday and it definitely improved but still getting the issue. Next decent day I'll go back out and do it againLet's hope to hear from Langley863 that his pedal drop is gone as well!
Progress!Was unable to get out and bleed it today but did yesterday and it definitely improved but still getting the issue. Next decent day I'll go back out and do it again
As dduelin suggests, the PCV is an item likely to retain air with its convoluted path. So step 3 is worth spending time on, pumping the brake pedal as dduelin did, moving a lot of fluid there and tapping (or vibrating if you have a way to do it) the PCV while doing it........ I used a vacuum pump but pumped the brake pedal to help the fluid along in the circuits fed by the rear master cylinder. Using at least two or three full reservoirs I moved a lot of new fluid through each circuit. All but one seemed free of air but the Proportional Control Valve finally gave up several good bubbles.........
I just do not see the logic of going through repeated flushing of the front MC system to try to dislodge air in the rear MC+ SMC system.If you do it properly there are less doubts
I doubt jf would bother flushing his front lines to very quickly move air out of the PCV!?When out riding, I could work where the bubble was located, and was able to flush it out very quickly. But when I try to explain it to myself - or write it down, I cannot make my logic work.
Plus his time and he is going to have to go at it several times, doing something unnecessary. He is not having issues with the front brake. Why mess with something that works?..... it's only a couple ounces of brake fluid.
Good you mention that. So Langley863 doesn't waste his time thinking he can completely eliminate the small drop.You can always feel a very slight dip in the pedal if you release the front brake (and in the lever when you release the pedal) - but that is due to the feel in the lever/pedal as the caliper responds to the other piston(s) in the caliper being released.
