Ron said:
Put the Sea Foam in the fresh gas, leave the fuel tank cap loose, bypass the vac. valve and go for a ride.
Note if anything changes.
Note about note: When troubleshooting, you should only make one change at a time and test, especially if you want to determine what the cause of the problem was.
Note about note about note: Notice the big goofy grin?
I worked in maintenance for over 40 years with most of that time trouble shooting broken equipment. Been riding 1100s for over 25 years/2-300 K miles. It's how I would approach it on my bike. I'd rather ride than wrench.
I'm more interested in riding than wrenching. Do all these easy things at once and start undoing them one at a time when the ride last longer than an hour. They all are easy to un-do.
It has happened numerous times so the gas probably is somewhat fresh.
The bike runs OK for an hour or so then starts stuttering. The carbs are probably OK. The Sea Foam might help but probably isn't needed. Don't worry about the Sea Foam, it'll be OK to leave it.
Tighten the cap and ride another hour or more. Easy to do and after it runs OK for more than the hour, easy to un-do it (tighten cap). If it doesn't run OK after tightening the cap, loosen it again. Leave the tank flap cover unlocked and loosen it while riding, if you can. The cap being loose keeps a vacuum from forming in the tank as the fuel is used. The cap allows air to flow into and out of the tank. Cap repair:
Fuel Cap Repair/Rebuild ( ST1100 ) *
www.st-riders.net
The vac. valve bypass test isn't too difficult and can be undone just as easy. "It was repaired before the problem." Why was it repaired? How long did it run, without problems, after the repaired? Many guys have tried and the repair failed or didn't last. It takes 10 minutes to remove plastic, 10 minutes to bypass valve and plug vac. line, 10 minutes to install plastic. Or save 10 minutes and run without the plastic. Easy to undo the bypass.
If nothing changes, that leaves the pump. At $500 from mother Honda, that would be a considerable thought process for me. I would futz with the several alternatives on this site first. But the question is do you have more time or money.
That's about all the mechanical fixes. What are the electrical possibilities? Fuel pump relay or coil intermittent when hot?
