After hour ride, bike starts stuttering or missing.
Ron
Orlando
ST1100s
2432
Anyone have experience with the QFS replacement pumps? I've seen reviews that say they work great, and some that say they work too well, and flood the carbs. They claim to be designed to work in ethanol fuel, which sounds great, since the one that's in there wasn't. Oh--should mention that even though it's an old bike, it only has about 35K miles on it. Still waiting on the petcock parts, so I haven't torn into it yet, but maybe this weekend.
While you're waiting, do the bypass. It's a 5 minute job with the plastic off and 5 minutes to un-bypass it. Don't forget to plug the vac. hose.
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
Check the 4 vacuum tubes that are used for balancing the carbs. If they are leaking air, that can cause stuttering behaviour, and the tubes themselves have been known to split after many years (Or so I have read on these forums). Behaviour has been reported to change as the engine heats up and the tubes become more flexible. 3 tubes are capped, the 4th is the rear right which is connected to the fuel shut-off valve instead.
Traverse City, MI
1998 ST 1100
8865
I am having the same issue with my '01 with 33k on it. I fueled up but didn't get the gas cap on right initially. I smelled gas after two miles and discovered the cap issue and fixed it. Later rode about 70 miles and she starved for fuel and died. After sitting a while I managed to get her to start again, a cylinder at a time as described above. Had two more instances on the way home where she nearly died but managed to idle okay on the shoulder and then would run good. I have a new fuel filter and petcock rebuild kit. I'm not clear from the discussions above if I should test by riding until she falters, then loosen the gas cap and see if anything changes?
Slydynbye
Will ride for Pie
Fremont, California
2000 ABSII
7331
Loosening the cap will test for a clogged cap or vent hose.
If it's the vacuum fuel cut-off then a bypass will quickly solve it.
Many including me have bypassed the fuel cut-off permanently. The rebuild kits are often unsuccessful.
Traverse City, MI
1998 ST 1100
8865
Thanks for the info! So get this--Before I tore into the bike I thought I would ride it and try to duplicate the problem so I could do the gas cap test. I had the gas cap on tight but the "gas" label on the cap was upside down in the 6 o'clock position. I switched the cap 180 degrees, aired up the tires, and then drove it like I stole it for nearly two hours and no issues. Needless to say, I'm going to hold off until something happens down the road.
Slydynbye
Will ride for Pie
Fremont, California
2000 ABSII
7331
Sounds good but..
Familiarize your self with the vacuum fuel cut-off bypass procedure and make sure you have the tools with you or bypass now and never look back. One less thing to go wrong in my Book.
I did mine in the middle of Death Valley. Just Sayin. :oops:
kankakee
R1200rt
do the fuel cut bypass and replace the 20 year old fuel pump. After market pumps work well. Thats why UP carries a spare on his trips.
Washington
Ok, will do the fuel bypass, run it without for a while and see if the problem repeats before I fix the old one. I assume it's for safety/not flooding the carbs with the bike on but not running (I can hear it come on with the key to on)?
It cut out a couple times last night again, this time with the tank nearly empty, so it doesn't seem to be a vacuum in the tank issue. It doesn't happen with sustained highway speed during the day (it's been about 80 degrees pretty consistently), but it does happen when it's cooler at night. I'm able to start it with choke on after about 10 sec (even before stopping, just pull in the clutch, thumb the choke, and start it), and after the second time it happened, I reduced speed and limped home without incident, so flow does seem to be a factor, as does ambient temp. If the bypass doesn't work, I guess it's on to the fuel pump.
kankakee
R1200rt
the bypass is there to shut fuel off from the gas tank in a tip over. I had a tip over and no fuel escaped with cut valve removed. Many carb bikes don't have one.
Ron
Orlando
ST1100s
2432
When the tip over switch turns the motor off (key still turned on), does the pump keep pumping?
Montreal
2009 ST1300A9
I don't think that it has anything to do with that. From what I recall, it was in response to the EPA mandated sealed fuel systems and the new problems that that created.
I'd start with a visual of the cap vent line, folks manage to unintentionally flip the cap around during refills and twist/kink the hose in the process...
Washington
Probably EPA chicanery.
Anyway, pulled the petcock, waited for it to cool off out there, and went for a spirited ride. 30 min and no hiccups, despite continuous high rpm cruising (finally dropped to 4th just to see if I could increase the fuel flow enough to get it to starve itself out).
On a side note, I applied some dynamat extreme to the plastic handlebar cover today as well, and I think I solved the resonance problem there at mid to high rpm. There's a ton of room under the cover, and the dynamat is only a couple mm thick. Works way better than the foam I originally stuffed under it.
Washington
Took apart the valve today, the air side diaphragm is clearly torn, not surprising it was failing, I'm actually surprised it worked at all.
Got a better cap for the vacuum line, when I removed the makeshift one, there was some fuel in it--is that normal, or a sign of another failure to come soon?
Ron
Orlando
ST1100s
2432
Is the hose going to the carb or the hose going to the valve? No need to cap the vacuum valve hose. Cap the line going to the carb. I wouldn't think there would be gas in the vac. line to the carb.
Is the hose going to the carb or the hose going to the valve? No need to cap the vacuum valve hose. Cap the line going to the carb. I wouldn't think there would not be gas in the vac. line to the carb.
The vacuum hose is the one going to the carb (#3) and that's the one that should be plugged/capped after removing the shutoff valve.
get all the fuel out and monitor it. Since its a vacuum line it shouldn't have any fuel in it, but because it was previously attached to the valve with a split in the diaphragm fuel would be able to enter the vacuum line because of that. It may have been there before and you just didn't notice it.
BTW, when the diaphragm tears and allows fuel to enter the vacuum line, it sometimes flows into the #3 cylinder through the carb as raw fuel and can foul the plug over time. Pull the plug and take a look at it.
Washington
Plugs are new, I replaced them recently, and the old ones looked fine. The torn side was the vacuum side, not the fuel side, looks like both sides seal in their respective chambers. There is a small pressure equalizer in the middle chamber that vents to atmosphere, so it doesn't surprise me that a leak on the fuel side can be smelled.
Regardless, replaced both sides, and reinstalled the valve. I tried turning the bike on with only the vacuum line connected, to see if the valve opens (it does, although not very much), then put the whole thing back in and went for a ride. Seems to function, although there's little enough time/miles on it to yet claim success. I will say that the old one was obviously broken, and the new pieces seemed to go together without the misshapen business talked about in the write up, so we'll see how it goes.
Ron
Orlando
ST1100s
2432
Yes, I know that but I wasn't sure if he capped it or/and a hose to the valve. :)
Sounds like it's fixed! :thumb:
