:hyp1: Ok, the latest info on the $100 Oregon VRR. I charged the battery, let it set 1 1/2 hour. Voltage came out to 12.84. Cranked up the bike, at 2,000 rpm I got 15.22 volts. At idle I got 15.12 or so with it bouncing.
After the bike warmed up fully, the voltage at 1500 to 2200 plus rpm stayed at 15.04. When the cooling fans kicked on, the voltage rose to 15.22, fans kick off and it settles back to 15.04 after bouncing from 14.90 to 15.15 for short period.
At a 1200 rpm idle I get 14.70 to 15.02 volts and it finally calmed down and stayed at 14.99 volts. Fans kick on and it drops to the low 14's. Rev it back up to 1500 rpm and it holds 15.04 steady.
So with the bike hot and with the fans cycling, I'm getting a steady 15.04 above 1200 rpm and 14.99 at idle till the fans cycle. With the high beams (I've got the 65 watt bulbs) and the fans I saw it drop to 13.76 and it pulled the motor down a bit. It recovers and stays around 14.36 till the fans kick off. At 1500 rpm the lights flicker when the fans come on but, the engine stays steady and the voltage stays in the high 14 to 15.04 range.
So, I think its safe to run and see how it does with more than 10 mins of running. I couldn't take the Co2 from the exhaust anymore, it raining here in NC tonight. Had to work in a small garage in my Toy Hauler. :hyp1:
