I just finished re-installing my autocom (and XM radio). I sent it back to autocom to have the intercom overide shut off. The overide is what cuts music input volume by 50% when the intercom is in use. A good thing for some, but not so good if you tend to sing along with the music. At any rate, my first install was OK, but I had a lot of alternator whine at anything over 4000 RPM. So with lots of help from this forum I re-installed the autocom differently than I did the first time. I used a Centech fuse box and the relay that goes with the Centech. Then I connected both the XM power and the Autocom power through the fuse box. I grounded the fuse box to the frame using the right rear mount bolt for the foward seat height adjustment plate. The relay is connected directly to the power side of the battery, with the power for switching the relay on comming from the aux. fuse in line (using a T-Tap) under the left side cover. I fabricated a mount for the centech out of Stainless and used machine screws to attach it to the inside of the rear fender. All connections were heat shrinked, and I wire tied everything to the frame. I now have plenty of extra power connection possibilities for future audio upgrades (should be adding a Zumo soon), and the audio is now noise free at any RPM. Thanks to all who helped.
