Rob Hephner
Mobile Pest Control
This is in regards to the fitment of these tires on the ST1300 ONLY, not a review of the overall performance of these tires.
There has been some discussion in the past about the fact that Avon does not list a fitment for the ST1300 or Pan European. While many of us have used the tire without issue, there have been some issues and as you read along and look, you may come to the same conclusion that I have.
I ride aggressively and due to the fact that I actively teach Total Control I use more of a tires usable traction range than most. That being said I am not looking to get to the limits of traction and I want the most possible traction available in all situations.
First the photos. (I have bad lighting today, I?ll replace the Michelin Photos when it gets better.)
Rear (Storms then Road 2?s)
Front (Storms then Road 2?s)
These are tires used in the same way on the same range and right off the bat I can tell you I had more traction at full lean with the Michelins versus the Storms.
You can see I have a good millimeter or two left that is virtually untouched, now for the reason.
Compound is a great way to get traction, but the first step is to have more rubber attached to the road.
During the mounting process for the Road 2?s is when things first came to light. My previous 3 sets of Storms took about 110 to 125 pounds of pressure to get the bead to set and with one rear it was rather difficult. The Road 2?s set with about 70 psi. Now that might not mean anything to most but it showed quickly that the Storms are made for a narrower rim than in mounted on the ST1300.
The issue that results when putting a tire designed for a narrow rim on a wider wheel is that is stretches the tire out and makes a sharper edge at the side, thus making the contact patch at lean less, how much depends upon the difference, but the pictures above speak volumes.
I?ll be tracking the wear of these tire obviously, but it looks right off the bat as if the reason tat Avon does not list a fitment for the ST1300 is because the tire simply doesn?t fit the wheel. If you are never near the edge of your bike I doubt this is a big issue and it honestly hasn?t been an issue for my riding at the edge, but it is useful to have knowledge, so I figured I?d pass the information along.
