NOTIt's all good. That excedra is a nice looking tire and for a very reasonable price. Zeo and his machine have been through a battle. Tire mix is ok as long as it rolls straight.
I agree with John O. in that my experience does not support this contention. This is an ST1100 not a 1300. Honda calls for 36 PSI on the front for the 1100. I have had two ST1100's always run with 36 PSI front. I only had one front tire wear like that. That was the tire my first ST1100 was delivered from the factory with. The front wheel was porous and so it was constantly running on low pressure until I figured it out.That is your problem.
Run 42 psi in the front tire.
If you run 36 psi in the front you will continue to have a front tire that looks like your tire in the photo.
There is a reason this is the prime ST forum.
Any tire you choose will look like your photo if you run 36 psi.
NOTE: It's not your fault for following the sticker under the seat.
However, you have ruined a good tire prematurely by running 36 psi.
Michelin tires are prone to cupping because of the thread blocks. Look at a T31 https://www.americanmototire.com/battlax-sport-touring-t31-gt-120-70zr-18-59w-front/ the thread blocks are larger and will resist cupping better. . Many here are happy with the performance of the Bridgestone T31s' and it is reasonably priced . A cheap in price tire but a good tire are the Shinkos. Had a few, good mileage , no complaints. You can use a 120/70 zr18 shinkos verge https://www.americanmototire.com/search-results/?q=120/70-18&sort_by=price_min_to_max Great tire!The tire itself is a Michellin. Should I change to a different brand? What kind of tire is best for just daily commute over bad roads in Southern California freeways every day?
I checked BikeBandit (where I usu buy) and they show front and rear in Angel GT and T31's ship next day.I put a few more psi into my front tire yesterday before I made the trip home. I've been shopping for tires online, Revzila and a few others and 90% of the tires, especially the 'good' ones, are all "out of stock" for my size, which is 110/80/18.
Looks like normal wear to me. As a result of lots of highway miles. And not a lot of twisties
