Balance shafts
These are one of the most neglected adjustments on these bike.
Easy to inspect and adjust.
Engine must be stone cold.
10 minute job, really smooths things down.
The bike I did last night adjustments were off four lines on the top, and a couple lines in the bottom.
Manual is misleading.
Do NOT start the bike with the pinch bolts loose.
Loosen both, turn upper counterclockwise until resistance is felt, the back ONE line (using the dot for reference) then turn the bottom one clockwise until light resistance is felt, the back one line (using the LINE for reference) not the dot.
Then tighten the pinch bolts.
