Simple question : when the brakes are linked.... how do the front and rear communicate together : via wires and an electronic control box or via a simple oil brake hose ?
If it is via an oil brake hose.... it also need to be bled.
They don't communicate, they are designed to work together.
The front brake is hydraulically independent. The front lever and master cylinder operates both front calipers, operating the two outer pistons in each front caliper.
The rear pedal operates the centre piston in each caliper - so that is three pistons, two at the front, one at the rear.
The left front caliper bracket is designed to move. When the front caliper is operated - either by the brake lever, or by the pedal, the caliper bracket is allowed to move up a fraction. The movement operates a master cylinder which is mounted
on the front left fork leg, and this operates the two outer pistons on the rear caliper.
So whichever brake lever or pedal you operate, the rear brake outer pistons is always activated.
The balance of braking force is largely controlled by the size of the pistons, but that circuit to the two rear outer pistons is governed by the proportional control valve. Because the harder you brake, the more the weight on the back wheel reduces, and the more likely it is to loose grip and skid. To prevent this, the proportional control valve reduces pressure in the rear brake line to the outer pistons, as more pressure is put into it by the SMC.
The secondary master cylinder has no fluid reservoir, but is fed by the brake line to the front left middle piston. This means that in the garage, when you press the brake pedal, all 3 pistons in the rear caliper will activate. On the road, however, that route is effectively blocked off as the left front caliper is operateing the SMC.
The same system has been adapted only slightly for use in the ST1300.
