Got the carbs off after what seemed to be an eternity, the 90° elbows look fine to me apart from what i assume were 0-rings at some point, do you think I should just replace the elbows with new 0-rings, or replace the elbows as well, the hoses seemed pretty good as well, no cracks, or thin areas from what I could feel
I want to do a full coolant system drain and flush, does the radiator have to come off to gain access to the four cylinder drain plugs? Also how do I get all old coolant out, will removing the four drain plugs accomplish this
