...I just re-used the bolts. I'm guessing that they pulled some sort of safety rule on you and required you to buy new ones, or did you buy new ones willingly?
They used new bolts because the service manual calls for new bolts to be used. They didn't ask, they just did things the way the manual says they should be done - they are Swiss, after all. I'm very happy with that - the same shop has serviced my ST 1100 every year since 2002, and I have only ever had two breakdowns in over 150,000 miles of riding - the fuel cutoff valve failed when the bike was about 3 years old (I did a quick bypass at the side of the road), and I got stranded 2 years ago because of a melted wire (I did the "red wire bypass" to fix that).
I don't have any complaints about them replacing the bolts, I appreciate their meticulousness, nor do I object to the shop labor rate of about USD $155 an hour, but nearly $10 a bolt is irritating. That's Honda Europe's fault, not the dealer's, because it's Honda Europe who suggest the part prices.
Many safety-critical fasteners are
torque-to-yield, which means that when they are torqued to the specified force, the fastener deforms a little bit. So I fully understand and accept Honda's instruction to replace the fasteners. I have encountered similar situations on both automobiles and aircraft in the past. Almost without exception, the service manual requirement to replace a fastener is driven by the torque-to-yield nature of the fastener installation.
I might consider re-using a bolt that the service manual calls to be replaced if it is in a non-safety critical location, but I won't take any chances with the braking system.
Michael
