Seafoam still can't hurt you
Just for anyone's info, coil packs for the GL1500 are the same as the ST1100. I bought 3 coils for $60 a few years ago.So getting the coil packs from a guy who is parting out an ST1100 and everything should be good to go, not sure if just the wire or the coil pack so will probably just replace the whole thing once I get them.
So that is where I am at know, so by the time the coil pack gets here I should be good to go for rides again and get to enjoy the lovely weather we are having.
I ran seafoam thru two tanks and it did clear up a little bit, but after the synch it is WAY better.Seafoam still can't hurt you
No conservative riding here...........but with new carb boots AND idle mixes set BEFORE syncing, then go thru mixtures again..........then a final sync gets my scoot 50mpg all day long @80mph......yep.....believe it my friend. At times on a LD trip on the super-slab that will jump to 52mpg depending on mother nature.I have a 93 ST and I average 35 mpg on my daily commute of around 75 miles round trip. I hear people say they get into the high 40's and 50's but I think they must drive very conservatively to achieve those numbers. I used to think my bike was in disrepair since the mileage was so bad, but I think it has more to do with my driving style and hitting triple digits on the highway. I synched my carbs, but still get the same mileage. I do have some new carb boots on the way, hoping they will improve it some. But 35 mpg beats the 12 or 14 of my suburban all day and I usually arrive in half the time.
I synced my carbs last night for the first time using a Carbtune pro 2. Initially I had the airbox off so I could locate and set the adjusters. Cylinders 1+3 were out of sync with 2+4 but each side's cylinders were in sync with each other. Don't know if this is a common state of affairs when doing the syncing.No conservative riding here...........but with new carb boots AND idle mixes set BEFORE syncing, then go thru mixtures again..........then a final sync gets my scoot 50mpg all day long @80mph......yep.....believe it my friend. At times on a LD trip on the super-slab that will jump to 52mpg depending on mother nature.
BTW.......that sync is done with a MorganCarbTune or mercury stixs......and with all air intate in place(specificly specified by Honda). A CORRECT sync will NEVER happen using a flow meter.....period. Using nonsense like that without ALL intake/airbox in place IS counterproductive........better off to have just left it as was.
Not an opinion here folks, just the facts, which can be backed with results in comparison.
Sorry for the rant, but you all that use a flow meter can look at the results on that meter all ya' want, but without the airbox on, the airflow, its direction and velocity gives a far different result thru the venturi than with it on, which changes airflow, even a small varience between the four.
