Hi , I have 2001 st 1100. has 35,000 ks on it just purchased a few weeks ago .should i change the timing belt?
A better question would be, has anyone seen any signs of ageing or wear on these belts when 'inspecting' them. Aside from one post I've not heard of anyone who observed any visible wear/signs of age on their timing belt. As already mentioned, the old ones look very much like the new one. In the end, you are going to have to make your own decision...To change or Not to change, that is the question. Whether tis nobler in the mind to suffer the slings and arrows of a broken belt, or to do the dang maintenance against a sea of troubles......Following this post with interest as an st1100 newbie . Is there a way of just inspecting the timing belt without removing too much stuff? I have 79k kilometres [50k miles ?] and I assume it has the original belt ,bike is 2002. The belt age worries me not the mileage; any thoughts? ta
Take care. Laurie
Inspection is quite easy. Remove the 2 side service covers (2 Allen head bolts, each side), then at the front of the engine, there are 2 black plastic covers of the timing belt that I believe are held in place with 3 bolts each (be careful not to drop these), then ease the covers off. I changed my belts due to age, but as others have said, they looked as new. It is technically a gamble to not change it, but a gamble you’d likely win. Maybe more valuable maintenance would be the changing of the hoses of these bikes that are under the carbs and main radiator hoses as well as O rings and metal elbows. Even those looked good when changed on my bikes (but were done when the bikes had 35K miles or so).Following this post with interest as an st1100 newbie . Is there a way of just inspecting the timing belt without removing too much stuff? I have 79k kilometres [50k miles ?] and I assume it has the original belt ,bike is 2002. The belt age worries me not the mileage; any thoughts? ta
Take care. Laurie
yeah, the question that's not always obvious from the OP is are they asking about spending a few bucks on the timing belt and replacing it themselves, or going to a mechanic and spending a small fortune having someone else replace it for them. Self-replaced for a few bucks is an easy call, but when you add in the cost of the other pulleys it starts to add up.It is technically a gamble to not change it, but a gamble you’d likely win.
Now normally I would be 100% with you on using genuine Honda parts but I did read somewhere a valid point about how old is a NOS Honda timing belt? Can you even get a newly made belt from Honda? I don’t know. They suggested getting a (newly manufactured) quality aftermarket belt instead. I have a similar quandary to the OP, my bike is 20 years old yet mileage is low at 12000 miles. For now I have decided to ‘ignore’ it and I’m slowly working through a long list of maintenance jobs (mostly detailed on the very helpful buyers guide) and building confidence with it. Finding a dealer/garage locally that I trust to take the job on would need a lot more research. I don’t want to spend £500 giving the job to someone else to make a mess of it, I can do that myself for free.The "book" says check the belt at 60K renew the belt at 90K.
Been in the trade more years than I care to remember (40+) and at one time looked after a fleet of 40 Transit minibuses.
We used to renew the cam belts every year (High Mileage) and the old ones would look like new. having said that we still got the occasional breakage even with new belts fitted. Not very helpful I know.
I did attempt to "Check" my ST1100 (1998) as it approached 60K, but found, unless you want to strip a lot of bits off, you can't see a great deal of the belt and every thing I could see was as new.
As one of the guys mentioned there is always the nagging thought in the back of your mind when out for a run, and I personally decided get it done at 60K and then forget about it. At the time my bike was 20yrs old and belts do age being largely rubber.
Not heard of any failures on ST1100's until very high mileages, every thing about them is very well made in my opinion and built to last.
If any one is going down the belt changing route I would strongly suggest always fit genuine Honda parts, and change the tensioner & idler pulleys at the same time.
Cheers.....STeve.
Quite a number of parts are identical across Honda automotive/power-sports/power-equipment...Can you even get a newly made belt from Honda?
That's a good point, Anybody know how to tell the age of a NOS belt? or even a new aftermarket belt come to that given that the 1100 went out of production in 2001, could be some 20yr old "brand new" belts out there ??Now normally I would be 100% with you on using genuine Honda parts but I did read somewhere a valid point about how old is a NOS Honda timing belt? Can you even get a newly made belt from Honda? I don’t know. They suggested getting a (newly manufactured) quality aftermarket belt instead. I have a similar quandary to the OP, my bike is 20 years old yet mileage is low at 12000 miles. For now I have decided to ‘ignore’ it and I’m slowly working through a long list of maintenance jobs (mostly detailed on the very helpful buyers guide) and building confidence with it. Finding a dealer/garage locally that I trust to take the job on would need a lot more research. I don’t want to spend £500 giving the job to someone else to make a mess of it, I can do that myself for free.
Everybody seems to use the Gates 325 belt which appears to be the same one Honda used originally anyway, and is easily available online.That's a good point, Anybody know how to tell the age of a NOS belt? or even a new aftermarket belt come to that given that the 1100 went out of production in 2001, could be some 20yr old "brand new" belts out there ??
