I agree that oil can cause problems, every one I have seen is a slippage that shows up when the clutch is dumped, a very slow engagement but once engaged tends not to slip after it sets.
This one sounds like it is not engaging even with the clutch lever released. A worn pivot will reduce the throw of the slave cylinder,
I wonder if the pushrod maybe misaligned in the piston in the slave cylinder, or the clutch itself. Something is holding the clutch from engaging, a misaligned pushrod will still feel like the lever is still having play as the free play is built into the master cylinder. If the clutch is assembled in the correct order ( and I am not saying it wasn't ), It almost has to be mechanical, The slave cylinder pistons will leak if they get cocked in the bore and won't do anything other than drain the fluid.
Seems like you are down to taking something apart again, The slave cylinder is easy to pop off to check anything there. You probably won't find anything there but it easier than pulling clutch again.
