Commo Advice - FRS? GMRS? etc.?
Trvmtchll
Circleville, Ohio
1995 ST-1100
9067
I would go Gmrs give you alittle more range vs the FRS with the capability of higher power and the Gmrs just require a fee to get your license we run GMRS while camping and have built a mobile repeater to get us more range
Well we haven't discussed roof top semaphore flags yet...
That's because the roof is where the Thule storage case lives. Smoke signals from the exhaust would be preferable.
@Shuey, you sure opened a can of worms with this question...but it's been entertaining.
Sadlsor
Birmingham, Alabama
2008 ST1300A
9065
I disagree; we are abusing him, whether good-natured or otherwise.
But in many cases, that is the STOC Standard Operating Procedure, so I doubt he is actually surprised.
It can be entertaining to see what direct-to-ditch hijacks some of y'all come up with. My concept of "silliness" has been of necessity, modified several times since I've been hanging around here... while simultaneously confessing my own complicity sometimes in this same silliness.
Houston, Tx
2003 ST1300
5952
Thanks for the responses so far.
- Checked out Sena and all I could fine was their Sena Freewire. It's basically a CB with bluetooth capability. But . . . pricy.
- Cell phones, we'll have them in any case.
- FRS radio range seems tied to watts output.
Found this pair on Amazon and available locally at Best Buy. 1.8 watts and 18 hours of run time.
Plus, these have 60 channels of FRS AND 14 channels of GMRS (without a license requirement)
Found these two at Walmart:
2 watts and 18 hours of run time
1.5 Watts and 9 hours of runtime.
Thoughts?
Shuey
Shuey
Shuey
Niceville, FL
FJR1300 ES, 2018
SPOT
LINK
7005
Thanks all and . . . I'm enjoying ALL inputs, even . . . the dumb ones! o_O
Decision is made: Midland X-Talker Model T71VP3 which has 2.8 watts and has both FRS and GMRS channels.
I'll test them out locally then the real test on "the" trip in a few weeks.
Shuey
Obo
East Coast Canada
'03 ST1300A
@Shuey looks like a great choice. Kudos for filtering thru the legit inputs and our dumb ones. :nuts:
We never did talk car carrier pigeons or Morse code flashlights...
Martha Lake
F900 XR
000800
Does it matter if Shuey made a decision? This is a lot better than an oil thread. ;)
Camarillo, Ca
2006 ST1300A
002552
Good choice.
use FRS low power car to car. It is all you need and will save the batteries.
If you are worried about being too far apart then use an external ( 6 db) antenna mounted high as you can (roof rack).
A good antenna mounted high is way better than more power in a poor antenna (rubber duck).
Have them use google maps on their phone with GPS tracking turned on, and they could follow the blue line home........
