The bad fuel has to be long gone. I have put on more than 1200 miles since I accidentally put 87 in the tank. That was just the first time it set the code????
I think I will replace thermostat and first confirm left or right knock sensor with a extension wire swap. Great ideas. But Thermostat will be replaced. I will update later. So much to pay attention too when reading the gauges at the time of no failure and failure. I never much gave too much attention to thermostat as generally it is pretty warm here and running at 3 bars in normal for me.
Must change thermostat as it really appears to be bad as it stuck open. Regardless of what is going on, it needs to be replaced. So I will start there and then see what happens and use a wiring jumper if I still set a code on Knock sensors. I noticed in manual the knock sensors were under exhaust pipes.
Again, great ideas and thoughts,
Thank you,
Rory
Thank you,
Rory
