I always appreciate all the wonderful help on this group, all comments.
I sometimes think it is like a right of passage to become a true ST1300 Owner to tear off the plastic until you can do it blind folded, like I used to be able to do with my M16. I have Peripheral Neuropathy from AO exposure. I have no feeling in my hands among other things and because of this, it is very difficult to handle these small screw/bolts/nuts and not to mention that it is easy to cut/tear/burn my skin without knowing it. So, if I can get by with only one experience of dealing with the plastic, that is what I am trying to do, to limit my exposure of hurting myself. It would be nice to have normal dexterity to do these normal things, but i do not look forward to do it one time, maybe twice, but trying to limit the times I remove the plastic.
I have a thermostat on order along with the O Ring needed to replace it. I hope to have an ECU in hand about the same time.
My first approach is to change the ECU/ECM as it is the easiest to do for me. It doesn't hurt to have a spare ECU/ECM as finding a new one is difficult and maybe finding the 03-07 used one will become more difficult as more time passes. If that doesn't fix the problem, then I am game to pull the plastic. I believe the life of this bike will probably outlive me. LOL
I know this is probably not the most practical way to approach this problem, and I am not trying to be hard headed about the plastic, but I just feel this is what is right for me. I have only seen the two bars one time since I have had owned the bike, and that was when I drove it at sub 50, like 44 degrees air temp. I normally don't ride when it is that cold here so it is possible the thermostat has been bad for some time. I mean the bike is 12-13 years old. And is not driven as often as a car is. That is an average of only like 2800 miles a year. Actually, you can almost put that much mileage on it just by going to the two or three bike events we have here a year. I live about 30 minutes South of Daytona. So, I am really not a every day rider. I used to ride more often, but as of the last few years, I have not road as much. My new lady friend rides a Harley and a BMW, so I am riding about every weekend now.
Again, not sure the Thermostat is cause of my problem, but is due to be replaced....
My Bachelor degree is in Computer Engineer Technology which later came to be called a Computer Science Degree. My graduate degree was in management. I learned working in IT, "if it ain't broke, don't fix it" ... and I have applied that to most all my things I do. Sometimes you add new problems by changing things that have nothing to do with the problem. I am just a bit hesitant to change the thermostat until I am able to fix the FI problem. I have not seen one thread where the Thermostat fixed the FI error code 26? I just don't want to add to the problem. With few exceptions, my symptoms have almost always been caused by a bad ECU/ECM. I just wish someone was close by that I could exchange ECU/ECM's with.
Don't give up on me yet, I plan to concentrate on Gas Mileage this weekend. Prior to and during the code fault and if it sets, to keep bike moving, power off and power back on, and then reset the MPG and see what my mileage is before setting the code. The MPG is bugging me the most. I also can tell that at idle I seem to be missing a bit, and that is with three bars. If all else fails, I will pull the plastic and make everyone happy and get my ST1300 Riders Badge... LOL If I know if has a tiny miss in idle and higher RPM, I believe that might have something to do with it, but not sure.
i agree with Mark (Blrfl) on all that he says as well as others. I did start my bike again on the Center Stand and it warmed up and went right up to three bars, and the fan would come on and off just as he indicated. I ran the bike up and made sure it was warm, and it never went to 4 bars. I have only seen it at 4 bars one time, and that was on Main Street in Daytona, dead stopped, on and off, around a bunch of really hot bikes give off a lot of heat. I was burning up and the temp was like 90 outside. You are right, I have a lot of variables into my problem. Lets see if I can name them ....... problem didn't present itself until I put in 87 octane gas and if you read a lot of the threads, this seems to be a common link to this problem and has almost always turned out to be and ECU. It seems putting low octane gas sets things into motion??? Never seems to fail on Center Stand in gear.... speed related 75-80,.... gas mileage decreases..... feels like hitting a wind gust... a little bit of throttle seems to move through the wind... top end of speed doesn't seem to be a problem... cold weather saw 2 bars, only one time.... thermostat may be bad....
I want to check something this weekend. I plan to clear my MPG and see if I am always getting poor mileage all the time or just after the code failure. What is strange, once it sets the code, I can power off the bike and drop the speed down and turn it back on, and it will not set the code until I get up around 75-80. I just need to confirm for myself, am I only getting poor mileage at the time the code is set, or does my poor mileage occur all the time, at random, or all the time.
Again, thanks for the wonderful help and insights. I guess does anyone feel that the Thermostat is causing my problem or is just something that needs to be replaced? Has anyone seen a bad thermostat set the FI code? If it is stuck open will it have the effect of the large MPG loss I am seeing?
Thanks and a great site...
Rory
Rory
