First time rear wheel removal on a shaft drive
Devon UK
Hope this doesn’t sound stupid but I’ve never removed the rear wheel on a shaft drive. Getting a new rear tyre on my ST1300 tomorrow,now before putting the rear wheel back in I intend to grease the splines,what grease is suitable for the job please?
Thanks in anticipation
Josh_ST
I love my 2 wheeled therapy machine!
Marysville, OH
2003 Honda ST1300
000237
Auckland, New Zealand
8901
I use this stuff, Molybond GA50, 50% molybdenum disulphide paste.
Fort Worth, Texas
91 ST1100/06 ST1300
Read Larry FIne's post. Same stuff I've used since the mid 1990's. Never an issue with spline wear, clumping, whatever.
CYYJ
Michael
Toronto & Zürich
None any more.
2636
...what grease is suitable for the job please?
Hi Rocky:
Lots of good answers above.
Be aware that it is CRITICAL that you use a grease with a very high moly contents - often, this product is called an "assembly paste". If you use any of the exact products specified above, you will be OK. But if you just pick up a tube of "moly grease" at the store, it won't have sufficient molybdenum content, and that will result in fairly rapid failure of the differential at the rear of the moto, necessitating a $2,000 + repair.
Michael
This has been the occasional subject of other threads. You might read these before venturing forth to work on your bike:
This is a good one:
Some of those links will take you to the middle of a thread. To get the real flavor of the discussion, just scroll up or down and click on the first of several pages
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
The other criteria is that the paste is suitable for high pressure situations. Dow Corning told me that mineral based products were better for that than silicone based. I don't know about Lithium based alternatives.
Rocol and loctite as described above are two of the most widely used products. I use the Rocol now my M60 has nearly all gone.
P.E.I., Canada
2005 st1300
Honda recommends it's M77 and while it's suitable, I find it is expensive and only available from the dealer. The other recommendations given, such as the loctite would be my choice, for that reason alone
Hi Rocky:
Michael
In the USA eBay final drives and driven spline hubs show up all the time for $200 or less. Not that anyone should factor the low price to replace it instead of using the correct lubricant to maintain it but it’s not an expensive repair if it came to that. Has anyone actually had to replace a final drive in the history of ST-O?
Honda recommends their M-77 for this application. There are other owner recommended pastes but M-77 will do the job and many dealerships will have it in stock.
California
I got flat tire in the rear wheel and I have just removed rear wheel couple days ago to get it done tire patch and i was applied M77 paste tube from Honda dealership that we always have in parts inventory. I forgot the loctite 50 at home so i was using m77 paste for temporary after installed rear wheel back on then will remove it again and apply the right stuff.
So i drove it around 80 miles later and remove rear wheel again to apply loctite 50. Guess what, m77 paste was drying up to small balls that i could see it. Luckily, i clean it up and still in good condition and apply Loctite 50 about 5 grams to both sides.
Honda 60 is discontinued so i’d say and recommend everyone getting Loctite 50 is the best choice for now.
Moly60 was highly resistant to separation in the tube but Honda superseded M60 with M-77 over 10 years ago. I recognize there are choices other than Honda M-77 but Honda is the one with skin in this game.
Unlike M60, M-77 will separate in the tube and if the tube is not kneaded prior to opening the product will not be applied properly. I've noted this in previous threads.
So do we need a thread with precise instructions as to the acceptable kneading technique to make sure the product will perform as designed? Not the first time that M77 has been reported to dry up in little balls, seems like Honda screwed the pooch on this recommendation.
Tell me, what do you do when you open a can of paint and see that the pigment has separated from the liquid? Mix it or complain that Sherwin Williams screwed the pooch?
I’ve had to replace (3) male/female driveshaft units due to spline damage, one of them the owner used moly grease, the other two, were dealership serviced, and Honda M77 was used.
In that case I can easily see that something needs mixing, and can easily see when its properly mixed, so you're not really making a fair comparison. If I'm using a mystery compound inside a plastic tube that I can't see through to observe the state of its contents, its apparently a crapshoot figuring out if and when its properly mixed, based on multiple reports of it balling up after being applied.
I have opened up many rear wheels in the last couple of years that used M77, and always found the same thing….rust colored, dried up, little balls that had fallen away from the area that they were supposed to be protecting etc.
Maybe many of the trained Honda tech’s didn’t read the proper instructions either :rofl1:
Rocky ST
Devon UK
Wow
There’s a wealth of information there,many thanks.
I’ve just had a look on David Silver spares (used them lots in the past) now they have a moly grease listed in there ST1300 section. Now I don’t know how to insert a link,but here’s a screenshot of it
Is this what I’m looking for?
Thanks once again
Grand Rouge
Rosemont CA
05 ST / 83 GS 1100E
What did Honda do wrong with the final drive splines? Excessive wear within a thousand miles...A few have stated a hundred miles....with low percentage Moly. I have 3 Ford F350 trucks and 2 Ram 2500 vehicles. Diesel powered. Couple of em putting out 1,000 pound feet of torque. Often pulling 12,000 pound loads behind, often steep grades on construction sites. Never once has there been a spline failure or U Joint CV joint failure, front axle spline etc. lowest mileage truck 68,000. Highest 179,000. Grease / Paste......no high moly content....grease / paste easily cleaned away with brake cleaner or kerosene....and a couple of rags.
Here we are beating away at each other, fearing the 2,000 dollar spline and "differential' replacement costs...er....differential? ST1300 (for one) does not have a differential.
Younger brother has an 06 Triumph Rocker III. Coming up on 70,000 miles. Rear tire generally changed 4,000 miles.
So regular rear drive service. Torque around 160 pound feet. HP about 140. Liqui Moly grease of choice. Splines ....appear as new.
Just asking.....whre did Hoda screw up?
I fail to see how one knows what was applied, when and how, and what product was used if they didn't apply it or see it applied.
Since everyone but Honda knows what to use for spline lubrication I'll sign off this thread. I have nothing else to offer.
