rwthomas1
I agree entirely. I've spent the better part if my life building, re-building, modifying, tinkering, fiddling, etc. with all manner of engines. While I do very much enjoy Fortnine's vids, this one is simply BS. I was unaware of Honda's two different V-twins. But they sure do prove the point. The topic he attempts to provide insight on is incredibly complex, it can't be done any justice in a 10min vid.yeah, I remember that as well, but haven't kept up on the latest race engine tech since the 2-strokes went away years ago.
But, in the case of the video, I think he's not really doing anyone a favor by stating that the HP difference between the Indian and Harley engine designs can be summed up in their bore/stroke measurements. As you started to state, many other things change as those dimensions change, its not as simple as "change X and Y will result" like he makes it sound. A larger diameter bore can support larger (or more) valves to improve the flow of intake air, rev higher without blowing up due to the shorter stroke, and inhale a full gulp of air more efficiently than a narrower, deeper cylinder.
The whole concept of engine design and optimization is extremely complex, uses computer models, empirical data and prototypes rather than hard theory, and has so many different variables that its disingenuous to try to simplify it to the simple basics he presents in the video.
And in the end, if Harley had just attached the pistons to a somewhat normal crank configuration, their HP figures would be similar to the Indian HP figures regardless of bore/stroke dimensions.
RT
