Hey guys, I have all the parts to do the 40 amp update on my '94 ST1100, but cannot find an alternator base 11202-MAJ-G20. I've called everywhere from Partszilla to Bike Bandit. I have everything else. Any ideas?
Try David Silver, they may be able to help.Hey guys, I have all the parts to do the 40 amp update on my '94 ST1100, but cannot find an alternator base 11202-MAJ-G20. I've called everywhere from Partszilla to Bike Bandit. I have everything else. Any ideas?
I checked that one, looks like everything is sold but the frame and a wheel. ThanksHi Ned, I am the bearer of bad tidings. The base plate is no longer available from Honda. I just went through the same search a couple weeks ago. I did a fleabay search and messaged every seller of alternator or engine parts until I found a seller with one. There is a an add for an engine up here on CL $125. I think I saw a plate on the motor.
I'll give them a try thanks.David Silver
When I was looking I called Partzilla, David Silvers, a dealer in England and a dealer in Canada. They all source from Honda.Try David Silver, they may be able to help.
thank you John, so for a non-mechanic like myself can I take the bike with it’s inoperative (model year 93) stator and the new alternator to a mechanic to perform the service? What additional parts do I need to provide them to make this efficient for them?Ben, there is no 40-amp stator. The ST1100 was manufactured with two different charging systems:
- 91-95 - oil-cooled 28amp system with stator and external VRR
- 96-02 - air-cooled 40amp automotive style alternator with built in VRR
To convert a 28amper to the 40amper you use some of the parts common to both (Alternator Shaft Assembly - split-gears, bearing, flywheel...). See the link I posted in your other thread. Also, here’s some images that should help:
Error - ST-Riders Media Gallery
www.st-riders.net
Edit: answered here (direct link to post #12):thank you John, so for a non-mechanic like myself can I take the bike with it’s inoperative (model year 93) stator and the new alternator to a mechanic to perform the service? What additional parts do I need to provide them to make this efficient for them?
Best, Ben
Thanks John, I ordered the block and it should be here next week. I haven't started taking the bike apart yet. Didnt want to until I was sure I had all the parts. I'm sure that this will all make a whole lot more sense when I get your kit and start taking things apart. Thanks again.Can someone please post an image of the 1996-2002 alt fuse block?
Ned, go here: http://www.st-riders.net/index.php?topic=942
and click on “John’s list of tools, parts....”
once there scroll down to “If you use the OEM fuse box” where you’ll find the 40amper’s part numbers.
I first used the huge, 8AWG inline fuse holder you have when I did mine. RPITA! Not recommended. I have run the Littlefuse for 130K+, but if I were to do another I‘d use the Honda OEM fuseblock. I’ve recommended that for years. It bolts right up.
The wiring will make sense when you see the documentation with the kit. Pretty simple. The silver courtesy phone is standing by...
This '94 ST has no ABS, right? It's a standard ST1100?...
I have one really fuzzy question though. The wiring. I'm not understanding it. Mechanics I know...electrics not so much. John has said to use the Honda fuse block, but as far as I can tell that's just a fuse in a box? I've already spent way more money than I ever thouight I would. That stinking base plate cost me $260! Plus the new alternator I already bought!
I have a 60 amp maxifuse blade type fuse that I was able to get at NAPA and a cool water proof fuse Maxi fuse holder like the one in the pic that I can easily mount next to existing accessory fuse block. It looks like it has 8 gauge wire. It's heavy duty! So if I use this, does this just go in-line between the alternator and the battery?
And I still need to figure out which wires to do away with that are there. I'm hoping a lot of this will make sense as I start into this, but I'm confused right now.
Any insight and explanation that I dweeb could understand would be great!
Thanks
Yep. For folks doing the upgrade with salvage parts, I recommend doing just that. And that they talk the breaker into sending the whole alt shaft assy assembled instead of taking it apart for just the plate and shaft parts as they’ll never sell the other parts in the assy... no call ever for them. Of course charge/pay only for the plate, shaft and bearing, 1/2 of retail for new parts. If they won’t go for that then it‘s their labor to break it down...Then what would be wrong with buying a used, 1996 or later, wiring harness from a standard ST1100? Swapping harnesses might be challenging but for some, not as challenging as doing surgery on the existing wire harness
