Front Brake Pad thickness?
ATLANTA, GA
How thick is the meat on the pad? Not the whole pad just the part that wears away.
I bought some after market pads and they look too thick
New Jersey
st1300 '04
7163
Sorry I don't have a fresh set of pads.
Front or back?
iirc ebc being same for front or back means there back is thinner than oem but I don't know if they are thicker than the oem fronts.
TMUS
MSF Instructor 32 years
Quincy, Michigan
2006 ST1300a(Marvin)
7054
seen you had bydawg bars so I edited my post. I too only have EBC in waiting, sorry
Scooter
This space for rent...
Germantown, WI
2019 BMW R1250RT
5929
Just picked up a set tonight.
For the front pads, part # 06455-MCS-G02 the friction material thickness is 4.08mm as measured with my vernier calipers. Same measurement from both pads. Turns out the backing metal plate has almost the identical thickness...
BakerBoy
It's all small stuff.
Golden, Colorado
1408
I measured my new 06455-MCS-G02 front brake pads in late December before I installed them--I bought the pads a couple years ago and had them on the shelf. Every one of the 4 pads had 3.5mm of friction material on them. Interesting that yours had more Scooter. :)
Scooter
Germantown, WI
2019 BMW R1250RT
5929
That's interesting BB. Just for grins I decided to check the second package and both of those pads also measured roughly 4.08mm also. I'm measuring the total thickness of the friction material including the "wear bar" portion which does seem to be about 0.5mm thick. So maybe that explains the difference between our measurements.
For future reference, the rear pads, Honda part # 06435-MCS-G02 measures 5.25mm and 5.20mm of friction material for both pads respectively.
BTW, crazykz picked up this sets of pads for me. Maybe he has more clout than the rest of us...
BakerBoy
Golden, Colorado
1408
I did measure the wear bar portion as well, included in the 3.5mm on the OEM front pads.
The rear two pads (06435-MCS-G02) I just put on my bike had 5.1mm of friction material.
Seems like Honda (or crazykz?) thinks you need to slow down better, Scooter! :D
Britman
ATLANTA, GA
Those pads didn't fit too fat. Had to buy Galfer from local CycleGear
Local Honda dealer (Ha-Ha) didn't have OEM or non OEM.
Firstpeke
NT1100D
UK
Honda NT1100
7764
The thick ones will fit the rear, won't they?
OEM rears are thicker than the fronts...
Did I repeat previously posted information..... it's been a long day....
RONST1300
STOC # 8616
Council Bluffs, IA
8616
l love how you guys have converted to metric so well. I thought I was doing well with the wrenches. I must have a MENTAL BLOCK. LOL
Ron
"So there is one reason to ride a Harley."
RONST1300
STOC # 8616
Council Bluffs, IA
8616
l love how you guys have converted to metric so well. I thought I was doing well with the metric wrenches. I must have a MENTAL BLOCK. LOL
Ron
My non OEM cheapos from eBay measure nearly 5mm.[/QUOTE]
Oregon
Just an update since my new rear pads just arrived. Superceded by part number 06435-MCS-G03, measure about 5.4mm thick, with maybe .05mm variance between the two.
