How did the stuck axle guy fair out? What was igofar’s solution? Is this proprietary info?
Amazing what can be prevented with a fingertip of marine grease upon assembly......the brute strength hammering knocked the flange bearings out of the spline assembly, and still remained rusted/frozen to the axle...
Never thought of anti-seize. I've been using a thin layer of wheel bearing grease since I began rebuilding old bikes, also with no issues but it does tend to clump in spots depending on how stringy it is. Will give the anti-seize a try.Grease would be nice, however, some greases heat up and go away, I find a thin film of Anti-seize better for axles.
If you use grease on a Harley axle, you'll be pounding it out with a very large ball peen hammer next time.
A thin coat of Anti-seize will still be there for the next tire change, and you won't have to pound it out.
Dang!... but no matter how little I use, I can't seem to avoid getting it all over something.
I’ve made a number of tire changes on my ST1300 in the 70,000 plus miles. No problems removing axels but I always put a thin coat of wheel bearing grease on the axles to protect them from rust or corrosion. Did the same for my ole 80,000 Valkyrie 1500.Anyone here ever have the rear axle literally seize in the shaft drive assembly and left side wheel bearing? The last time I had the rear wheel assembly off the bike was June of 2012 when I installed the 2011 BT 023’s. The wheel spins on the axle but, the axle will not budge any further than 1/2”…even with a 4lb plastic dead blow hammer.
My next step if I cannot resolve this myself is the take the offer Dave Stradling, owner of Honda Powesports of Troy, OH, offered me.
He’ll let me borrow his tiltable motorcycle trailer with wheel chauk to transport my ‘07 STA to his Service Department. His guys will use the brain power and experience of their techs along with the Honda Techline and their traveling dealer service rep to resolve this dilemma. And, mount my new T32 GT tires. All for $99/hour + parts and $50 per wheel to mount and balance. Could be 3 weeks before they can get to it.
In the meantime, I can’t wait to ride my ST with the new T32’s and RaceTech Gold suspension upgrade.
And, in August he’s raising his shop rate to $119/hour because he has to.
