GIVI 56 liter top case
Rhome Texas
2011 ST_1300 PA
9102
I'm looking to buy a Givi 56L case, the Amazon ad shows it being almost 19 5/8X19 5/8X24 5/8 inches in size, my question is, is it really that big, or are they using the shipping box size? Can anyone post a pic on a ST 1300
Josh_ST
I love my 2 wheeled therapy machine!
Marysville, OH
2003 Honda ST1300
000237
This is the best pic I've got at the moment, pretty sure mine's a 46L Givi case rather that the 56L also.
Josh
Josh_ST
Marysville, OH
2003 Honda ST1300
000237
I believe this is the info for my case, possibly you can locate the case you're wishing to buy on here as well. I bought mine second hand from FBMP.
Josh
STRider
Oregon
2012 ST1300A
50
With the optional lighting kit. Do you want me to measure it?
Here's the link to the Givi listing
RichKat
Rhome Texas
2011 ST_1300 PA
9102
Thank you for the info, your posted dimensions look about right, I think Amazon lists the box it comes in size
Looks fabulous on your ride
Clickit
CLICKIT the PHOTOGRAPHER
Texas
2006 ST 1300
000200
9084
I have the Maxia dimensions 23" wide 16" depth 12" height. 2004 will have all the plastics and mount back on Thursday and if you would like a pic just let me know and will post
West Fork, Arkansas, USA
How did you wire the lights? I've got the Givi E215 Monokey plate on my ST, installed by a previous owner, but it has no place for the electric contacts in the lighting kit. ‍ I could MacGyver it with some JB weld, but I'm curious if there's an easier neater solution. TIA
Willsmotorcycle
Ride more...
Makefield Highlands PA
2016 ST1300P
003726
Post a picture of what's coming out of your top box now, it will be easier for solutions.
I don't have the top case yet, I'm planning the install. I intend to get the V56 case that STrider shows installed, that's why I quoted his post.
The problem is that Givi only has the E215 Monokey plate for the ST1300. It doesn't have a provision for the electric contacts that are part of the E160 light kit for the V56 case.
Richmond, VA
'01 & '96 ST1100s
9007
Ok, mea culpa! My Givi monokey plate does have the knockout for the electrical connection. In my defense I saw the remark on Amazon from one of the vendors selling the E160 lighting kit, that it was not compatible with the aluminum versions of the plate, which mine is. I have no idea of the age of the one on my bike, so when I checked it for the knockout I didn't look closely enough. Looking again, even though it is aluminum the spot for the connector is where it should be. No MacGyvering necessary
STRider
Oregon
2012 ST1300A
50
Yes, to everything said in response to your questions @ARsouth40
If you go with the Givi E160 kit then you can wire into the brake light circuit without cutting wires if you have the terminals and connectors (I refuse to cut OEM wires if it can be avoided). There's a bundle of connectors to the rear of the right side valve cover where the rear brake light switch connects to the harness. There you can pick up the brake light. I've shared pictures of those connectors here in the past, but I can post them again if you'd like.
If you choose the Admore product, then you'll need access to the taillight, brake and signal circuits which may be hard to pull off without cutting wires.
The Givi E160 kit is more complex than that on the E52 case with the E97 light kit. On the E52 the lights are in the bottom half of the box so the only contacts are between that and those you install in the Monokey plate. However on the V56 they're in the lid, and those brilliant Italians (I am one) chose to use a second set of contacts to bridge the gap between the bottom and the lid instead of running a wire across the hinge. Terrible design IMO
Good luck!
JohnK
Bonney Lake WA
2012 ST1300a
8814
I had the contact set up but after a year of on and off with the trunk - it started to mis align and the lights didn’t come on. Then I hard wired them to my brake light that has a flasher so it adds to the rear view when I’m braking - I like the v shape as it’s uncommon so peeps pay attention more. I also added leds to the trunk red lens wrap around - hard wired and tacked down the wires with a glue gun. The wire ends have a connector to remove the set up
STRider
Oregon
2012 ST1300A
50
@JohnK I may find myself following your path at some point. I think the weak link in my setup is the lid to base connection as opposed to the base to plate connection. Running a wire across the hinge inside should not be a big deal.
JohnK
Bonney Lake WA
2012 ST1300a
8814
Yes I agree the lid was suspect too.
