TwoBrittanys
aka itsbent
Morons?
Posted via Mobile Device
May be, but its also the most intelligent design for an air cooled two cylinder engine along with Moto-Guzzi. You'd have to try very hard to overheat one.The BMW with the cylinders sticking out the side is the most ridiculous looking motorcycle ive ever seen. I would rather be riding a mountain bike than that thing
How does that make it MORE efficient? If the chain is slack, doesn't that mean some power is lost taking up the slack when power is applied?Chain drive is marginally more efficient than belt drive, due in part to the fact that a belt is stiffer and pulled tighter than a chain, which has slack in it.
Agreed, but we're not talking about race bikes. My Buell has plenty of torque and the belt seems to handle it just fine for my application.Chain is able to handle much more torque than a belt. No race bikes use belts, especially in drag racing.
I admit I'm lazy, but because I would rather ride than spend time lubing, adjusting, or changing a chain, I'm not a real man Do I get any points towards real manliness for changing my own oil?The down side to chains: slinging lube and frequent adjustments. In other words, they're not for the lazy riders who just want to ride, ride, ride .. and who take their bike in to a real man for maintenance with their wallets held out in front of them.
Not all V twins are flawed. The Yamaha Stratoliner carries 5 plus quarts of oil; Harley carries 3 quarts. The liner has a sump to the rear of the cylinders and an oil cooler in the front. It circulates the oil very nicely. Does it run hot? Of course. Does it overheat easily? no way. 25,000 miles before it was totaled, there were no heating issues. My brother in law's 07 Ultra classic will roast your goodies, but it does have beautiful paint and two valve technology.
Also, that hard surface coating Itsbent refers to on the sprocket is the 'case'. Sprocket teeth are case-hadrened and bear up very nicely so long as stretched chains are replaced regularly and chain lube is used generously.
Some morons have taken to using WD-40 on their chains .. incredibly .. simply because it's "cleaner". Probably raised by their mothers ..
That's what has me scratching my head. It wasn't warm at all while this was happening.That's a problem with any bike that rides slowly...
Even an ST1100 will have issues if the ambient temp is high enough... trust me on this one...
Then what's the radiator and cap, the thermostat, and fan for then?The ST will not 'cut off' it'll just get so hot you could damage the heads.
