Headlight Bulb
CHICAGO
its time.. one of my headlights went out. ive been reading lots of ppl upgrade.i wondnt mind upgrading the headlight ..but then again theres cost.any simple upgrade suggestions?? thanks
British Columbia
2021 RE Meteor 350
Simplest upgrade, if not already done, is to install 55/60W H4 bulbs in place of the OEM 45/45W.
Auckland, New Zealand
8901
I just put some LED bulbs in my 1100. This is a plug and play option, the LED bulbs are a bit of a squeeze through the rubber boot, and I used double-sided tape to fix the driver units to the back of the headlight shell. Access was by way of removal of the screen and panel above the headlight. I'm very happy with the output and spread. Make sure to buy LED bulbs that include a small shroud in front of the front emitter, reduces glare to oncoming drivers and maintains a stock cut-off on dipped beam.
finger lakes ny
1999 ST1100
7959
55/60W H4 is fine Matt (Honda H4 55/6 .. 34901-MC7-601AH $7.92 need shims), but I bet you'll like the LEDs a lot more, and they are more or less the same to install.
WIGAN, UK
ST1100, 1998 non abs
I used the higher watt h4 bulbs with a blue tinge to them, very effective and not too expensive , top tip when removing the old bulbs is to use a small mirror to see the retaining clip, as you have to use the force without one:D
Ron
Orlando
ST1100s
2432
I went with a European headlamp assembly. More expensive but any H4 fits right in. Better light dispersal pattern also.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
+1 You did ask for simple. Not so cheap though. Any aftermarket bulb, capsule, or LED for cages should work if their light source closely approximates the OEM bulb filiments' positions.
John [shielded (low beam) HID in the right reflector for ~140K, PIAA 910s under the mirrors]
moddy
the mod
Seymour, IN
05 ST1300
8843
I installed DDM Tuning, has worked for 3 1/2 years. I also installed a bypass switch for power to ballasts until after the bike is started, more for colder weather and lower cranking amps. This technique was utilized because it was demonstrated by a 1300 owner the HID may not come on without a solid power source to the ballast.
The bypass switch has also been helpful to leave off when I am working on the bike with the key on without the engine running. Less draw on the battery.
I bought extra bulbs to have on hand, have never used them yet. Your expense would be 35.00 less. Others have installed HID's on this forum as well. Less draw than stock system, more light.
1Pair of Mounting brackets for 35W DDM Ballasts
HID-Bracket-Slim-35W$2.99
1Apexcone HID Bulb, H4 High / Low, 5000K, Pair
Bulb Color: 5000K
Bulb Type: H4/HB2/9003 Hi/Lo Beam (+$20.00)
APXBULBH4HL.5000K$35.00
2DDM Motorcycle HID Kit, 35W, H4 High / Low, 5000K
Bulb Type: H4 Hi/Lo
Wattage: 35W
Bulb Color: 5000K
DDMMoto35W.H4HL.5000K$75.00
Subtotal:$112.99
Shipping:$22.31
Sales Tax:$0.00
Total:$135.30
moddy
the mod
Seymour, IN
05 ST1300
8843
I will also share with you a technique for the cheapest solution that I've done, but takes a special touch. Auto parts store H4 bulbs, cut off the 2 lower tabs. This bulb can be placed with special care because the sheet metal housing of the bulb's mating surface can be seated before the retaining spring is secured.
They do make a 10.00 pair of shims you can place on the automotive bulb, with the two lower tabs cut off, that simulate Honda's OEM bulb replacement. It is on that thread that I learned about this "sweet spot" the bulb can be placed with it's single tab before the spring is placed.
I used this technique to place a bulb a few months before I installed the HID's.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
N.B. If you cut the two lower tabs off an H4/9003 bulb and use the shim, be sure to flatten any remaining bulge at the root of the tang so bulb casing fits fully flat on the shim (top tang too). Otherwise the bulb will be canted, moving the filament out of its optimal position. A dab of Honda Bond or sumsuch helps keep them together. FWIW
Waaaay back when I put Cibiē headlights in my cars and 750-4 all the H-4 bulbs I saw had heavy tabs that weren't easily bent. They even had an extruded groove that made them stiffer.
Fast forward a few decades and the Stanley H-4 bulbs I got from Honda had tabs about twice the thickness of a foil gum wrapper. They were easily cut of with diagonal cutters.
But—I can see they could very easily be evenly–folded back enough to provide a slight friction fit in the headlight shell. I think this would avoid the balancing act of getting a single-tabbed bulb properly in place while positioning the bale. I don't know if this would work with all H-4 bulbs. I don't recall any ridge in the bulb holder that would play hob with the two bent tabs.
EDIT: I didn't realize that this thread is about an ST1100 and I was talking about my 1300. Then I realized John O's ride is an 1100 and realized the OP must have an 1100 too. Sooooo forget I said anything. :)
Motorsports Racing Capital of the World
1992 ST1100
8648
I did the LED lights with the cutoff deflector and used the Honda to H-4 adaptor shims. Going this way was a lot less money than HIDs or even regular halogen high performance lamps.
The LEDs are very bright. Should last longer than factory and match the color of my Cree driving lights. I have a ST 1100.
