Computer Nerd
full frontal nerdity
Thanks again for the advice. I will try the insulating material.
Not really, but I don't keep it in there when I'm riding. It gets some heat if I chuck it in there after I stop, but the engine isn't pouring more into it and leaving it in there all day in hot weather hasn't been a problem. (I do park in a garage at work, which probably makes some difference.)So being veldro'd higher up in the pocket keeps it out of some of the heat?
Keep in mind that air temps inside a passenger car can exceed 170?F just sitting in the sun (here in AZ). Consumer electronics, at least the quality stuff, are pretty tough these days and have to survive just being left on the seat of a car (which can get hotter than 170?). I still think the repeated exposure to high heat + road vibration in a fairing pocket isn't the best thing for phones, iPods, or whatever. If I still had my ST I'd probably be lining the fairing pockets with some thin foam or something on the inside so whatever is in them was protected first from vibration and second from direct heat transfer from the walls of the compartment. I'd rather be a little extra cautious than have my cell phone croak when I needed it most.Those thermal images are great!
I was thinking of getting a new cell phone, so I think I will begin carrying my older phone in the storage box, and see if there are any ill effects.
I was thinking the same thing-expanding foam!Has anybody tried the expanding insulating foam spray, the type used in the building industry ?
I know it is designed to keep heat in but I should work both ways.
I know it is horribly messy, but I may be possible whilst the fairing is stripped off and when set it can be cut and shaped as required.
I was thinking of a thin (difficult I know) layer all over the outer surface of the fairing pockets.
If no one has done it I may give it a try as the summer is approaching.
I may even try rock wool if I can keep it in place and do some temperature measurements similar to what VINTAGEMXR did.
Ray
