Heat That's too much heat-ST1300
Georgia
Honda ST1300
I decided to wax the bike really good the other day, and discovered that the bottom under carriage on the left side by the kickstand was melted. I could not believe it . I tried to trace it down and see if It was from something else, but I don't suppect anything. It melted pretty bad. Could this be from too much heat from the pipe?, and why would the other side look fine? I am also trying to find out if the bike is still under warrenty if honda would replace this and access the problem. I was really shocked to see this!
002760
Re: Heat That's too much heat-ST1100
On an 1100.. that's something unusual.. would the carbs being out of sync cause one side of the exhaust to run very hot and do this?
Uncle Phil
4 ST1100(s)
006717
698
BIGMAN - Check to make sure the mounting screws are in correctly. The lower cowling can be a pain sometimes to gte properly positioned. There's no back screw on that side like there is on the right side that keeps it off the exhausts.
002760
We are assuming it's a 1100 because of your thread title. Maybe change that so people will come read and help?
I actually added the ST1100 to the title based on his profile showing ST1100... I just changed the title to show ST1300.
darn, George has more ammo now.
002760
Pictures would help... I've yet to see anyone show it that hot... some have had aftermarket tank pads slide around because the glue got hot and melted... some have had areas on their legs burned.
I won't say there is no heat problem because for some it is there. I believe it's a small number and most will tell you the bike gets hot when it's hot outside and also tell you to wear gear but I honestly think it has more to do with syncing up the throttle bodies than anything else.
Georgia
Honda ST1300
I just took some pics of the melting, but I don't know how to down load pics. Any help with that issue also?:turtle
Calgary, Alberta
06 ST1300
7376
Those pipes look like they get a lot hotter than normal, mine are just slightly discolored at that point. I'd be checking the operation of my engine, timing, maybe running too lean?
Georgia
Honda ST1300
What do you suggest that I should do as a first measure of action?
002760
That appears to be a 2003. That is the only year model that DID NOT have the additional heat shield riveted into the lower section.
If you look at this pic, you'll see the difference, 2003 on top and 2004+ on bottom:
Here is the article that shows how to save some money getting a 2003 lower cowl and replacing it with the 2004+ heat shield saving some money:
https://www.st-owners.com/forums/showthread.php?t=20004
I agree with david that the pipes still look like they are getting hotter than they should though.
Georgia
Honda ST1300
I have a 2004 it has the metal shields on the backs of them. Is that part covered under waranty?
002760
Doh!... sorry, guess I was looking at the frame color.. boy, I need to hit the road...
I would assume it is covered... maybe while they are at it they can diagnose why it's that hot... you never know, they may actually come up with something.
Georgia
Honda ST1300
I had just posted a little while back about the bike running rough and losing compression. The bike was probably running very lean during that time. The bike has 62,000 miles and was not melted until just recently. Other than that I really have no idea what could be the problem.
002760
Have you looked at the plugs?
+1 have you ever changed the plugs?
Georgia
Honda ST1300
I will check them. It seems like the bike is running pretty smooth though. There is no hesitation at all running idle at 1,000 rpm.
Scooter
This space for rent...
Germantown, WI
2019 BMW R1250RT
5929
Unless you have the extended warranty your warranty is likely expired. (Normally 3 years/unlimited miles from date of purchase)
