Warranty is good thru nov. of 2011Unless you have the extended warranty your warranty is likely expired. (Normally 3 years/36K miles from date of purchase)
Ummm, my factory warranty was 3 years/unlimited miles. Extended warranty bumps you up to 7 years.Unless you have the extended warranty your warranty is likely expired. (Normally 3 years/36K miles from date of purchase)
Maybe forget to tell them that you could have possibly had bad fuel!After hearing responses from others in this thread that makes all the sense in the world because it had not melted up until just recently when the bike was running so rough. I had just changed the oil and did not see the melting. I will still probably see if since the bike is under warranty still if honda will replace the bottom cowling.
This is exactly what I was going to suggest. It looks suspiciously like an exhaust leak to me. I would pull the muffler-pipe and replace the exhaust seal ring with a new one from Honda. Its a soft graphite type ring .Bigman did you check and see if you have an exhaust leak near the melted area? If not I would also suspect the lean condition to have caused this.
