Some helpful install pics:
The right side of the headset:
That's marked for parts fiche line 7 and master cylinder line.
The left side of the headset:
Marked for parts fiche lines 5 and 1. Note the steel tab on 5 (8 mm hex head below the 5). The HEL does not have this tab. I
fabricated a tab out of 1/8 aluminum stock.
That's a 1/4-20 carriage bolt and nylon insert lock nut.
Marked for lines 7, 1, and 5
The (right fork) pipe mounting bolt was pushed to the right four or so mm so could not be inserted. I tried a different approach. With the pipe unattached to the forks I tightened the connectors. I mounted the nylon block to just the right fork by 4 or 5 threads. With the pipe pulled away from the forks I inserted the mounting bolt for the left fork. With some thumb pressure I got the left mounting bolt started about 4 or 5 turns also.
Tightening each side a few turns at a time brought the pipe evenly to the forks.
There are two pipe connections forward of the shock. Here's what it looks like up there:
This is looking in through the battery location. Lifting the HEL connectors will expose more of the 13mm hex. The connection can then be tightened and pushed back down. The mounting nut for the HEL blocks can just be seen on the left, next to the line. The mounting bolt is welded in place.
A cheat sheet for the front. The measurements in red correspond to the length of the HEL lines and help ID them.
