2003 ST1300A. Just purchased with the fault, no history on the vehicle except that it has been sitting for 2+ years (with a presumably dead battery).
Symptoms:
HISS light turns solid when key turned + killswitch in run position, HISS light doesn't turn off after that.
FI light stays on.
Fuel-pump not running.
Starter will crank over the engine, but won't fire.
Steps taken so-far:
Battery fully charged and tested under load. Voltage is good, condition is good.
Neutral-switch works (verified by being able to turn it on/off by changing gears)
Kill-switch works (HISS light turns solid when switched to run)
Side-stand switch presumed working (Starter shouldn't run when in gear and side-stand out, right?)
I've felt and manipulated the wires from the HISS antenna to the main cable-harness to search for breaks. No change.
My diagnosis:
Faulty HISS antenna or ECU.
Now, what I haven't done is to try and "re-program" the keys. Can the ST1300 forget about its coded keys when left without power for an extended time?
Symptoms:
FI light stays on.
Steps taken so-far:
My diagnosis:
