I just replaced my SMC. I don't know why I was putting it off, it wasn't that hard. At someone elses recommendation, I did a full bleed in the order outlines in the service manual of all 6 bleed points on the Calibers and the Proportional Control Value. I'm glad I did. It was quite yellow and I pushed through everything to get good clear fluid from all points. Then, when removing the SMC, I of course had to drain the lines that lead to the front left caliper.
Everything is back together and I'm going back through the bleeding process, obviously with a lot of air in the system, and my front master doesn't seem to be pressuring anything. It's not pushing any fluid out at all. Is there a trick? I have confirmed that I only have one bleed valve open on my front caliper attached to the SMC. Thanks for tips.
