I recently upgraded to Sonic Springs also using Sonic Springs' recommendations and Mr Bertrand's methods as a guide. I had a leaky seal, so I replaced bushings, seals, and springs at the same time. FYI, at 82k miles the bushings were still not worn thru the teflon coating.
Thank you very much Mr Bertrand
, by the way. Your write up in MCN and forum posts were very helpful.
I didn't use the old spring/spacer as a guide, don't know what the preload was, but the sag was 40mm!
I stacked the new spring, washers, spacer (cut long to 135mm) and cap in the fork tube and actually measured. Then trimmed the spacer to 125mm, I think, to hit a 20mm preload target.
I diluted some Honda 5w and 10w to 7.5w, filled to 115mm and rode it. I haven't had a chance to remeasure sag, but I think it's pretty close to optimal for me. It's certainly not as harsh riding anymore, still needs some testing though. I do know... if the sags measures close to 30mm, it's not coming apart again for a while.
Yes a preload adjustable cap would be nice. Come on Honda.
Thanks again to all that posted personal experiences and recommendations on the forum.
