Greetings to all.
This is my first post to the forum although I have been lurking here for months. And I thank all the contributors for the volumes of great information.
I have a '99 ST1100 and it has an engine knock (strange as it may seem for this bike).
It has 40K kms on the clock and appeared to have been well looked after when I bought it a few months ago.
It can only be heard when fully warmed up, no knock when cold.
Loading up the engine (slipping the clutch with brake on) doesn't make it louder, but the knock increases in frequency with rpm's.
Here's what I have done so far;
Drained the gas and filled with 91 octane.
Changed spark plugs (I know, that never fixes anything).
Replaced the the oil with Amsoil 10W40.
Removed the carbs, they were spotless inside.
Replaced the coolant fitting "O" rings while the carbs were off.
Removed all the PAIRS equipment and the vacuum fuel valve.
Sync'd the carbs (single gauge method) they were pretty close to spot on already.
After each one of the above items, I re-checked for the knock and each time....still there.
I would be most grateful for any ideas or diagnosis. Please don't tell me it's a rod bearing
I'm not thrilled at the thought of following in Allen Millyard's footsteps this winter, but if I must, thank you in advance Allen.
The link below is for a YouTube video (and audio) of the knock. I couldn't figure out how to post a video here, maybe its not possible.
I held a mechanic's stethoscope probe to the engine near #2 cylinder and held the earpiece up to my phone's mic. Hope it helps.
Cheers, Paul
Nova Scotia
Cheers, Paul
Nova Scotia
