Raced home after work, hooked up the battery to the battery charger for about an hour and a half, then raced over to the dealer before they closed. Service rep brought out the portable battery tester, connected it to my battery, tested it, and the display showed "replace battery". No charge for the test. So, I guess I need a new battery, right? Not so fast....
On my way home from the dealer, I stopped at an Advance Auto Parts store and asked the guy if he could test the battery. Sure, no problem, he says. He connects it to the (bench mounted) tester, tests it, and the printout shows "Good Battery!" The printout also shows 12.64 V, 78 degrees temperature, and 209 CCA. The guy says that my battery is good.
Should I go for 2 out of 3 or just replace the battery???
I don't have any accessories on the bike. The most recent work I did (a couple of months ago) was change out the 45/45W headlight bulbs for some 60/55W bulbs, installed a powerlet outlet, and also installed a Stebel horn. I haven't used the powerlet outlet at all (only tested it by running a 12V portable inflator for about 20 seconds right after I installed it to make sure it worked). I occasionally toot the Stebel at an inattentive driver every now and then.
By the way, the dealer that the battery is not a warranty item. I've had the bike for about 16 months.
