Rob F
In my past inquiries on coolant leaks i have had quite a few members telling me that the waterpump weep hole normally has some leakage. That didn't seem right to me as i spent many years working on JD riding mowers and when they dripped fluid out of the weep hole there was definitely a problem.
This "don't worry about the weep hole leaking" scenario has been nagging at me so i started my detective work and i think that i found out something very interesting. I just need confirmation on this to finish off a theory.
So the question of the day is........... Do any of you riders that own a 2008 and up ST1300 have a fitting with a drain hose coming off the crankcase cover near the waterpump?
Where does that hose end up? Have you noticed coolant dripping out of the hose occasionally?
If i can confirm this, then my theory would go something like this:
From 2003 to 2007 there was no fitting and hose at the weep hole. There apparently were a lot of unnecessary waterpump replacements done under warranty because of customer complaints. When the weep hole leaks on a pre 2008 the coolant runs all over cover and along the oil pan and drips out of the plastics. Very messy and noticeable So to remedy ( or hide) this, Honda decided to install a drain hose( 2008 and up) and run it down somewhere so it would be less visible and messy.
My personal opinion is that there is a flaw in the waterpump design causing slight seepage past the seal. Perhaps sealing material, tolerances, soft impellershaft, ect. It was probably more cost efficient to just drill and tap the weep hole and ad a hose instead of redesigning the pump components.
