Have to give a shout out to the forum for some help here. About a month ago I installed new tires before a trip. and right away I noticed a steering wobble below 50 mph as soon as grip is released from bars. I normally keep a fairly relaxed grip on the bars and can feel the wobble, if I let go it gets much more pronounced. It's not a weave, but a front end wobble. I do all my own installs as I have access to a tire machine at work, and balance using a stand, have never had a problem until now. Steering head bearing were replaced 3 years ago, no notchiness detected or play, I double checked the drag with a pull scale, right around 3 lbs pull so right in spec. (bearing are oem ball bearings) Front axle bearing replaced 2 years ago (oem parts) smooth and no roughness or play detected. I thought I had a defective front tire so got the supplier to warranty it and send me a replacement. Same result. I took my trip anyway and all the while it had this issue, no obvious lumps or problems noted in either tire. I rode about 5000 miles on the trip - above 50 it feels fine even at interstate speeds. Now I'm back home and decided to get this sorted. I thought for sure I must have a defective rear tire that is setting this up, so I swapped it off for a used but still good T30 evo rear that I had. Exactly same wobble arrrgggh!! I have the used matching front t30 evo that I am going to mount tomorrow to see if that changes anything, just so I can eliminate the possibility that it could be something with the bike. Wobble seems more punctuated with my pillion riding along, but is still there solo riding. I checked rear preload is working and not low on fluid, knob meets resistance after 1 turn (topped up my preload fluid about 3 years ago). Do you think it's possible that I got 2 bad michelin front tires or has my ST suddenly decided it does not like michelins? Thoughts? Igofar? Help?
Cheers,
Geoff Forster
Cheers,
Geoff Forster
