I'm looking for a quality tire changing solution that doesn't involve a hitch (I gotsme no cage), and doesn't involve putting holes in concrete, an activity that upon which the landlord would frown.
Any suggestions?
Any suggestions?
Perhaps, find/make a good sized palet-like thing to bolt the machine to. Shouldn't spin if the operator is standing on it at the time.Some have mounted the floor versions on 2x4s or whatever works then mounted those on flat boards as well... I haven't seen that setup before but have heard it works.
+1 here. I used two piece of 3/4" 4x4 plywood, so the base is 1.5" thick. Works great.I also have my HF mounted to a 4x4 piece of plywood works fine as long as I'm standing on it while working.
Ditto. Standing on the plywood while pushing the lever around adds to the weight on the plywood. Keeps it in place pretty good.Mounted my HF unit on a 4 X 4 sheet of plywood, works great. Remove from the plywood to store.
I have my HF mounted the same way but it won't fit on the luggage rack.Ditto. Standing on the plywood while pushing the lever around adds to the weight on the plywood. Keeps it in place pretty good.
