Using Google translate:
Bore x stroke:
92 x 81.5 mm
Displacement:
1084 cc
Design type:
Two-cylinder, liquid-cooled, 4 valves per cylinder
Exhaust gas cleaning / standard:
5 euro
Power:
105 PS (77 kW)
at 7500 rpm
Torque:
104 Nm at 6250
Compression:
10.1: 1
Top speed:
not specified
Maintenance intervals:
not specified
Mass weight
Length:
2240 mm
Broad:
865 mm
Height:
1360 mm
Weight:
238 kg
Maximum payload:
not specified
Seat height:
820 mm
Standing noise:
not specified
Driving noise:
73 dB (A)
Power transmission
Coupling:
Multi-disc oil bath clutch with anti-hopping function
Circuit:
6-speed
Drive:
chain
Chassis & brakes
Frame:
Tubular steel frame
Front spring elements:
45mm upside-down fork, adjustable spring preload
Rear spring elements:
Pro-Link suspension
Spring travel v / h:
150 mm / 150 mm
Wheelbase:
1535 mm
Trailing:
108 mm
Steering head angle:
26.5 °
Bikes:
Cast rims
Front tire:
120/70 R 17
Rear tire:
180/55 R 17
Front brake:
floating 310 mm double disc brake, four-piston brake calipers, mounted radially
Rear brake:
256mm disc brake, single piston caliper
Tank capacity:
20.4 liters
price
Price:
not specified
