Determined that my carb boots need to be changed on my 98 st. It had the pop on warm up and the clamps were loose when tightened fully. I recall reading a very detailed guide with pictures to do this. I am unable to find that thread now. Could someone please forward me or leave a link that may help me with this. Thank you.
I just did the job for the first time a month ago or so, and its pretty straightforward, so if you can't find the thread it shouldn't be a problem. You need to remove the gas tank (the lower part that actually holds the gas, not the cover) to get good access to leverage the carbs out of their boots, then pry with a broom handle or something similar on the frame crossmember to pop them out. I used a length of 1" PVC that I happened to have lying around and that worked too. You don't have to remove the throttle cables, just swing the assembly around and hang it on the mirror (after popping off the turn signal housing). Take pictures along the way to aid in reassembly, there's a few hoses that have to be removed from the carbs before they will be free to hang on the mirror, you'll see which ones they are as you progress.
There was one hose on the front that was particularly stubborn in coming off, and I ended up damaging it a little bit so I bought a new one just to be safe. In my case I was doing more work under there so I disassembled everything before ordering parts anyway, so that didn't delay my job. If you've already got the boots and are trying to do it in one day, then be careful with that front hose, the rest all just pulled off with no problems.
To reattach the carbs put a little light lubricant in each of the boots and on the carb body, insert one side (I did left first because the right side had less stuff in the way to see what you were doing on the final push) and then push as hard as you can on the opposite side and it will eventually pop into place. Took a few tries before I succeeded, still don't know what was magical about the final push compared to all the others. You can also pull up on the frame of the bike with your other hand while pushing to get more force, it takes a pretty good shove to get them to seat.
