- Joined
- Dec 12, 2004
- Messages
- 1,282
- Age
- 76
- Location
- Weatherford, TX
- Bike
- '16 Versys 650LT
- STOC #
- 1134
JC, Below are a bunch of links I read and saved when getting ready to replace my SMC several months ago. There's a LOT on the board about this problem. Maybe this will save you a little time:I'll read through all the posts and learn as much as I can before the replacement unit arrives. Lot of time....
https://www.st-owners.com/forums/showthread.php?117970-SMC-Replacement
https://www.st-owners.com/forums/showthread.php?106729-Secondary-Master-Cylinder-FAILURE!
https://www.st-owners.com/forums/forumdisplay.php?456-ST1300-Brakes/page6
https://www.st-owners.com/forums/showthread.php?86791-SMC-Rebuild-Kit
https://www.st-owners.com/forums/showthread.php?118588-Advice-SMC-Replaced-Now-Only-Right-Side-Pads-Showing-Wear!
https://www.st-owners.com/forums/showthread.php?120746-Replacing-the-SMC
https://www.st-owners.com/forums/showthread.php?106891-Symptoms-of-Your-SMC-going-South!/page2
https://www.st-owners.com/forums/showthread.php?120665-Brake-bleed-experience&p=1519414&viewfull=1
https://www.st-owners.com/forums/showthread.php?68913-ST1300-Brake-Fluid-Replacement
https://www.st-owners.com/forums/showthread.php?53678-ST1300-Brake-Bleeding-Sequence-Cheat-Sheet
https://www.st-owners.com/forums/showthread.php?112313-Brake-Bleeding-Just-Made-Easier!&highlight
https://www.st-owners.com/forums/showthread.php?99645-How-much-fluid-required-for-change-of-fluid-through-Proportioning-Control-Valve&p=1526365#post1526365
https://www.st-owners.com/forums/showthread.php?101206-ST1300-Rear-Brake-Piston-Cleaning
http://world.honda.com/motorcycle-technology/brake/p5.html#01
Describes deflector shield removal and replacement, & packing bearings w/belray waterproof grease.
https://www.st-owners.com/forums/showthread.php?117099-Is-your-rear-brake-dragging
Recommended in the Silcon grease discussion:
http://www.autozone.com/autozone/accessories/CRC-8-oz-226-796-g-brake-and-caliper-synthetic-grease/_/N-268d?counter=0&filterByKeyWord=silicone+brake+grease&fromString=search&itemIdentifier=826455_0_0&CJPID=4175853&cmpid=cj
Silicon grease discussion;
https://www.st-owners.com/forums/showthread.php?101272-Rear-Brake-Caliper-mounting-bracket-question
