Dear friends
I'm replacing the rear tire in my st1300@2009 and following the guide ('Front Wheel Remove and Replace: a personal record') and got stuck.
The issue is the little flimsy clip that goes in the calipers. When I removed the brake pads, the clip dropped to the ground and I'm unsure how it should be installed back.
It seems to fit on either side (i.e. little tabs aligned to the left or to the right).
Is the below photo the correct alignment?
