The OEM brake light bulbs are white
They're white incandescent bulbs which produce a full spectrum of light that gets filtered by amber and red lenses to amber and red light. LEDs produce specific-ish frequencies of light from the full spectrum of visible light (yeah and
maybe some infrared too). So a white Incan will likely produce more red light outside of a red lens than a white LED does outside of a red lens. As Obo alludes - red LEDs behind a red lens is better than white.
Oznium, Cool White, Straight Black, P/N: 1320 is now ordered... The 'Cool White" is at 9,000k and the "Warm White' is at 3,000k. They are 6,500 lumes each. Hopefully not too bright!
Not to worry. Their rated output is more reasonable 25lm not 6500. 6500
K is a common color temp for headlight LED bulbs. 6500
lm would be get you stopped in a heartbeat with your license plate reflecting light into the eyes of following traffic. Even if it's 25lm per LED that's till only 125lm with is plenty bright to read a plate. You don't need white light brighter than your tail/turn//brake lights.
9000K+ is definitely more blue than white. Warm might have been a better choice.
I replaced my brake/taillights with LEDs because the factory rear tail lights just aren't bright enough in daylight to suit me. The delta between the LED brake and tail light illumination is significant so both are brighter without any doubt that I'm using the brakes.
There is still a hot spot as I haven't found an LED bulb that has the full spread of light for that application. Obviously vehicles with factory LED illumination have designed reflectors and lenses to work together.
I didn't use strobe bulbs for the factory lights because the I want those lights to be stock and not have the legality questioned by the uninformed. But I do have a strobe and a dedicated brake light only connected.
As always - pics of your handiwork are greatly appreciated. Maybe even a YT vid?
